Run Time: 0.001175
Run Time: 0.000280
Run Time: 0.001166
Run Time: 0.000320
Run Time: 0.004331
Run Time: 0.001019
Params: 0, e<, e<, XF\Pub\Controller\Forum, List, valid, , 1714830246,
Run Time: 0.000975
Params: 1714829346
Run Time: 0.000420
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 144 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1714829346)
Run Time: 0.000610
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 144 | Using where |
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1712238246)
Run Time: 0.001304
Run Time: 0.000985
Run Time: 0.000758
Run Time: 0.000211
Run Time: 0.000185
Run Time: 0.000256
Run Time: 0.001248
Run Time: 0.001738
bytes_received | 941792 |
bytes_received_change_user_packet | 714675 |
bytes_received_real_data_ps | 702668 |
