Run Time: 0.001251
Run Time: 0.000871
Run Time: 0.000375
Run Time: 0.002527
Run Time: 0.000594
Params: 0, O;, O;, XF\Pub\Controller\Forum, List, valid, , 1714840753,
Run Time: 0.000146
Run Time: 0.000804
Params: 1714839853
Run Time: 0.000473
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 127 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1714839853)
Run Time: 0.000679
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 127 | Using where |
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1712248753)
Run Time: 0.001569
Run Time: 0.001121
Run Time: 0.000882
Run Time: 0.000236
Run Time: 0.000326
Run Time: 0.000350
Run Time: 0.001635
Run Time: 0.002448
bytes_received | 941943 |
bytes_received_change_user_packet | 714826 |
bytes_received_real_data_ps | 702791 |
