Run Time: 0.001112
Run Time: 0.000675
Run Time: 0.002432
Run Time: 0.000479
:RO,
:RO, XF\Pub\Controller\Forum, List, valid, , 1714922982,
Run Time: 0.000825
Params: 1714922082
Run Time: 0.000495
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 171 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1714922082)
Run Time: 0.000638
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 171 | Using where |
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1712330982)
Run Time: 0.001176
Run Time: 0.000857
Run Time: 0.000946
Run Time: 0.000208
Run Time: 0.000229
Run Time: 0.000227
Run Time: 0.000295
Run Time: 0.000393
Run Time: 0.001560
Run Time: 0.001970
bytes_received | 946899 |
bytes_received_change_user_packet | 719782 |
proto_binary_fetched_bit | 2948 |
proto_binary_fetched_json | 4500 |
bytes_received_real_data_ps | 707577 |
