Run Time: 0.001315
Run Time: 0.000292
Run Time: 0.000791
Run Time: 0.000467
Run Time: 0.002554
Run Time: 0.000773
Params: 0, 㡄, 㡄, XF\Pub\Controller\Forum, List, valid, , 1714492469,
Run Time: 0.000958
Params: 1714491569
Run Time: 0.000570
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 21 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1714491569)
Run Time: 0.001099
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 21 | Using where |
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1711900469)
Run Time: 0.001924
Run Time: 0.001916
Run Time: 0.001072
Run Time: 0.000233
Run Time: 0.000387
Run Time: 0.000435
Run Time: 0.002524
Run Time: 0.000380
Run Time: 0.000243
Run Time: 0.002314
bytes_received | 941880 |
bytes_received_change_user_packet | 714763 |
proto_binary_fetched_bit | 2910 |
bytes_received_real_data_ps | 702736 |
