Run Time: 0.001599
Run Time: 0.000248
Run Time: 0.000743
Run Time: 0.000317
Run Time: 0.004424
Run Time: 0.001003
Params: 0, ݻy, ݻy, XF\Pub\Controller\Forum, List, valid, , 1714737917,
Run Time: 0.000630
Params: 1714737017
Run Time: 0.000628
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 100 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1714737017)
Run Time: 0.000913
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 100 | Using where |
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1712145917)
Run Time: 0.002192
Run Time: 0.001492
Run Time: 0.001585
Run Time: 0.000315
Run Time: 0.000270
Run Time: 0.001687
Run Time: 0.001437
Run Time: 0.000247
Run Time: 0.002110
