Run Time: 0.001088
Run Time: 0.000348
Run Time: 0.000261
Run Time: 0.001029
Run Time: 0.000364
Run Time: 0.004527
Run Time: 0.000712
Params: 0, 6?, 6?, XF\Pub\Controller\Forum, List, valid, , 1715073458,
Run Time: 0.000266
Run Time: 0.001020
Params: 1715072558
Run Time: 0.000623
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 122 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1715072558)
Run Time: 0.000724
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 122 | Using where |
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1712481458)
Run Time: 0.001490
Run Time: 0.002498
Run Time: 0.001305
Run Time: 0.000393
Run Time: 0.000353
Run Time: 0.000288
Run Time: 0.000469
Run Time: 0.000515
Run Time: 0.004815
Run Time: 0.000355
Run Time: 0.002665
