Run Time: 0.001189
Run Time: 0.001166
Run Time: 0.000467
Run Time: 0.002817
Run Time: 0.000760
Params: 0, 8-, 8-, XF\Pub\Controller\Forum, List, valid, , 1715077625,
Run Time: 0.000746
Params: 1715076725
Run Time: 0.000429
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 122 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1715076725)
Run Time: 0.000593
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 122 | Using where |
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1712485625)
Run Time: 0.001393
Run Time: 0.001220
Run Time: 0.000894
Run Time: 0.000340
Run Time: 0.000238
Run Time: 0.000244
Run Time: 0.000337
Run Time: 0.001856
Run Time: 0.002094
