Run Time: 0.001514
Run Time: 0.000378
Run Time: 0.001458
Run Time: 0.000631
Run Time: 0.004716
Run Time: 0.001148
Params: 0, Q^, Q^, XF\Pub\Controller\Forum, List, valid, , 1714858202,
Run Time: 0.001392
Params: 1714857302
Run Time: 0.000755
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 81 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1714857302)
Run Time: 0.001037
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 81 | Using where |
Run Time: 0.000391
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1712266202)
Run Time: 0.002913
Run Time: 0.001628
Run Time: 0.001465
Run Time: 0.000487
Run Time: 0.000402
Run Time: 0.000263
Run Time: 0.000414
Run Time: 0.000558
Run Time: 0.001976
Run Time: 0.000381
Run Time: 0.003736
bytes_sent | 23302 |
bytes_received | 944418 |
packets_sent | 286 |
packets_received | 3431 |
protocol_overhead_in | 13724 |
bytes_received_change_user_packet | 719713 |
packets_sent_command | 142 |
result_set_queries | 46 |
ps_buffered_sets | 46 |
proto_binary_fetched_bit | 2941 |
proto_binary_fetched_json | 4498 |
com_stmt_prepare | 47 |
com_stmt_execute | 47 |
com_stmt_close | 46 |
bytes_received_real_data_ps | 707525 |
