Run Time: 0.001184
Run Time: 0.000245
Run Time: 0.000707
Run Time: 0.000312
Run Time: 0.002834
Run Time: 0.000576
Params: 0, a=, a=, XF\Pub\Controller\Forum, List, valid, , 1714236247,
Run Time: 0.000657
Params: 1714235347
Run Time: 0.000372
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 121 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1714235347)
Run Time: 0.000531
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 121 | Using where |
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1711644247)
Run Time: 0.001289
Run Time: 0.001018
Run Time: 0.000762
Run Time: 0.000260
Run Time: 0.001345
Run Time: 0.002066
bytes_received | 941547 |
bytes_received_change_user_packet | 714430 |
bytes_received_real_data_ps | 702413 |
