Run Time: 0.001247
Run Time: 0.000753
Run Time: 0.000369
Run Time: 0.002752
Run Time: 0.000537
Params: 0, 4T, 4T, XF\Pub\Controller\Forum, List, valid, , 1714860658,
Run Time: 0.000137
Run Time: 0.000715
Params: 1714859758
Run Time: 0.000489
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 124 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1714859758)
Run Time: 0.000597
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 124 | Using where |
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1712268658)
Run Time: 0.001465
Run Time: 0.000983
Run Time: 0.000870
Run Time: 0.000292
Run Time: 0.000285
Run Time: 0.001779
Run Time: 0.002161
