Run Time: 0.001281
Run Time: 0.000209
Run Time: 0.000813
Run Time: 0.000313
Run Time: 0.003017
Run Time: 0.000604
Params: 0, M, M, XF\Pub\Controller\Forum, List, valid, , 1715031418,
Run Time: 0.000155
Run Time: 0.000994
Params: 1715030518
Run Time: 0.000555
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 111 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1715030518)
Run Time: 0.000669
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 111 | Using where |
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1712439418)
Run Time: 0.001734
Run Time: 0.001278
Run Time: 0.001101
Run Time: 0.000204
Run Time: 0.000222
Run Time: 0.000333
Run Time: 0.000336
Run Time: 0.001752
Run Time: 0.000273
Run Time: 0.002106
