Run Time: 0.001555
Run Time: 0.000280
Run Time: 0.000279
Run Time: 0.000865
Run Time: 0.000458
Run Time: 0.003296
Run Time: 0.000688
;d*,
;d*, XF\Pub\Controller\Forum, List, valid, , 1715091181,
Run Time: 0.000963
Params: 1715090281
Run Time: 0.001708
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 105 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1715090281)
Run Time: 0.000697
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 105 | Using where |
Run Time: 0.000255
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1712499181)
Run Time: 0.002107
Run Time: 0.001570
Run Time: 0.001182
Run Time: 0.000299
Run Time: 0.000322
Run Time: 0.000408
Run Time: 0.000415
Run Time: 0.001726
Run Time: 0.000222
Run Time: 0.005987
bytes_sent | 23314 |
bytes_received | 944414 |
packets_sent | 286 |
packets_received | 3431 |
protocol_overhead_in | 13724 |
bytes_received_change_user_packet | 719709 |
packets_sent_command | 142 |
result_set_queries | 46 |
ps_buffered_sets | 46 |
proto_binary_fetched_bit | 2939 |
proto_binary_fetched_json | 4498 |
proto_binary_fetched_blob | 1763 |
com_stmt_prepare | 47 |
com_stmt_execute | 47 |
com_stmt_close | 46 |
bytes_received_real_data_ps | 707519 |
