Run Time: 0.001366
Run Time: 0.000334
Run Time: 0.000267
Run Time: 0.001293
Run Time: 0.000443
Run Time: 0.004156
Run Time: 0.000926
Params: 0, P-, P-, XF\Pub\Controller\Forum, List, valid, , 1714859450,
Run Time: 0.000251
Run Time: 0.001084
Params: 1714858550
Run Time: 0.000489
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 86 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1714858550)
Run Time: 0.000725
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 86 | Using where |
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1712267450)
Run Time: 0.001724
Run Time: 0.001297
Run Time: 0.001104
Run Time: 0.000335
Run Time: 0.000282
Run Time: 0.000325
Run Time: 0.000313
Run Time: 0.000463
Run Time: 0.001582
Run Time: 0.000236
Run Time: 0.002007
