Run Time: 0.001212
Run Time: 0.000346
Run Time: 0.000922
Run Time: 0.000381
Run Time: 0.002925
Run Time: 0.000679
Params: 0, t>-, t>-, XF\Pub\Controller\Forum, List, valid, , 1715031551,
Run Time: 0.000155
Run Time: 0.000843
Params: 1715030651
Run Time: 0.000470
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 93 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1715030651)
Run Time: 0.000634
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 93 | Using where |
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1712439551)
Run Time: 0.001389
Run Time: 0.001308
Run Time: 0.001041
Run Time: 0.000379
Run Time: 0.000300
Run Time: 0.000343
Run Time: 0.000510
Run Time: 0.001619
Run Time: 0.000290
Run Time: 0.002036
