Run Time: 0.001791
Run Time: 0.000308
Run Time: 0.000356
Run Time: 0.001314
Run Time: 0.000555
Run Time: 0.004896
Run Time: 0.000751
Params: 0, ޔ|, ޔ|, XF\Pub\Controller\Forum, List, valid, , 1714318743,
Run Time: 0.001070
Params: 1714317843
Run Time: 0.000521
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 85 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1714317843)
Run Time: 0.000668
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 85 | Using where |
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1711726743)
Run Time: 0.001712
Run Time: 0.001743
Run Time: 0.001107
Run Time: 0.000325
Run Time: 0.000236
Run Time: 0.000314
Run Time: 0.000493
Run Time: 0.000480
Run Time: 0.001719
Run Time: 0.000301
Run Time: 0.003377
bytes_received | 941539 |
bytes_received_change_user_packet | 714422 |
bytes_received_real_data_ps | 702405 |
