Run Time: 0.001286
Run Time: 0.000239
Run Time: 0.000751
Run Time: 0.000363
Run Time: 0.002331
Run Time: 0.000647
Params: 0, t3u, t3u, XF\Pub\Controller\Forum, List, valid, , 1714848862,
Run Time: 0.000138
Run Time: 0.000735
Params: 1714847962
Run Time: 0.000478
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 76 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1714847962)
Run Time: 0.000681
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 76 | Using where |
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1712256862)
Run Time: 0.001450
Run Time: 0.001180
Run Time: 0.001043
Run Time: 0.000286
Run Time: 0.000253
Run Time: 0.000262
Run Time: 0.000523
Run Time: 0.001580
Run Time: 0.001962
bytes_received | 942270 |
bytes_received_change_user_packet | 715153 |
proto_binary_fetched_bit | 2927 |
proto_binary_fetched_short | 2379 |
proto_binary_fetched_int24 | 912 |
proto_binary_fetched_bigint | 8349 |
proto_binary_fetched_float | 145 |
proto_binary_fetched_json | 4439 |
bytes_received_real_data_ps | 703086 |
