Run Time: 0.001236
Run Time: 0.000209
Run Time: 0.000672
Run Time: 0.000298
Run Time: 0.002740
Run Time: 0.000572
Params: 0, 4UL, 4UL, XF\Pub\Controller\Forum, List, valid, , 1715104464,
Run Time: 0.000754
Params: 1715103564
Run Time: 0.000471
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 132 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1715103564)
Run Time: 0.000665
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 132 | Using where |
Run Time: 0.000262
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1712512464)
Run Time: 0.002323
Run Time: 0.001797
Run Time: 0.000965
Run Time: 0.000270
Run Time: 0.000230
Run Time: 0.000302
Run Time: 0.001393
Run Time: 0.001969
bytes_received | 946910 |
bytes_received_change_user_packet | 719793 |
proto_binary_fetched_bit | 2948 |
proto_binary_fetched_json | 4500 |
bytes_received_real_data_ps | 707588 |
