Run Time: 0.000942
Run Time: 0.000629
Run Time: 0.002469
Run Time: 0.000483
Params: 0, ه, ه, XF\Pub\Controller\Forum, List, valid, , 1716213555,
Run Time: 0.000137
Run Time: 0.000582
Params: 1716212655
Run Time: 0.000243
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 14 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1716212655)
Run Time: 0.000493
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 14 | Using where |
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1713621555)
Run Time: 0.001115
SIMPLE | xf_thread | range | last_post_date | last_post_date | 4 | | 39 | Using where |
Run Time: 0.000835
Run Time: 0.000758
Run Time: 0.000208
Run Time: 0.000155
Run Time: 0.000284
Run Time: 0.001468
Params: 24
- XF\Template\Templater->func() in internal_data/code_cache/templates/l2/s6/public/xgt_FrmIstatistik_yeniMesajlar.php at line 184
WHERE (`xf_session_activity`.`user_id` = 852) AND (`xf_session_activity`.`unique_key` = '852')
Run Time: 0.000228
Run Time: 0.001717
bytes_sent | 25082 |
bytes_received | 1018437 |
packets_sent | 334 |
packets_received | 3640 |
protocol_overhead_in | 14560 |
protocol_overhead_out | 1336 |
bytes_received_rset_header_packet | 1107 |
bytes_received_rset_row_packet | 303 |
bytes_received_prepare_response_packet | 230289 |
bytes_received_change_user_packet | 785484 |
packets_sent_command | 166 |
packets_received_rset_header | 123 |
packets_received_rset_row | 57 |
packets_received_prepare_response | 2897 |
packets_received_change_user | 506 |
result_set_queries | 54 |
ps_buffered_sets | 54 |
ps_prepared_once_executed | 54 |
rows_fetched_from_server_ps | 452 |
rows_buffered_from_client_ps | 452 |
rows_skipped_ps | 452 |
proto_binary_fetched_bit | 3246 |
proto_binary_fetched_bigint | 10631 |
proto_binary_fetched_decimal | 106 |
proto_binary_fetched_json | 5444 |
proto_binary_fetched_blob | 2044 |
com_stmt_prepare | 55 |
com_stmt_execute | 55 |
com_stmt_close | 54 |
bytes_received_real_data_ps | 771191 |
