Run Time: 0.000874
Run Time: 0.000628
Run Time: 0.002478
Run Time: 0.000477
Params: 0, t, t, XF\Pub\Controller\Forum, List, valid, , 1714323052,
Run Time: 0.000148
Run Time: 0.000670
Params: 1714322152
Run Time: 0.000346
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 54 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1714322152)
Run Time: 0.000563
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 54 | Using where |
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1711731052)
Run Time: 0.001240
Run Time: 0.000906
Run Time: 0.000802
Run Time: 0.000153
Run Time: 0.000251
Run Time: 0.001195
Run Time: 0.002033
bytes_received | 941537 |
bytes_received_change_user_packet | 714420 |
bytes_received_real_data_ps | 702403 |
