Run Time: 0.001305
Run Time: 0.000388
Run Time: 0.000804
Run Time: 0.000297
Run Time: 0.002768
Run Time: 0.000649
Params: 0, K, K, XF\Pub\Controller\Forum, List, valid, , 1714999553,
Run Time: 0.000798
Params: 1714998653
Run Time: 0.000482
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 114 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1714998653)
Run Time: 0.000906
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 114 | Using where |
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1712407553)
Run Time: 0.001494
Run Time: 0.001249
Run Time: 0.001935
Run Time: 0.000291
Run Time: 0.000272
Run Time: 0.000189
Run Time: 0.000295
Run Time: 0.000361
Run Time: 0.001879
Run Time: 0.002152
bytes_received | 946885 |
bytes_received_change_user_packet | 719768 |
proto_binary_fetched_bit | 2948 |
proto_binary_fetched_json | 4500 |
bytes_received_real_data_ps | 707563 |
