Run Time: 0.001443
Run Time: 0.000265
Run Time: 0.000267
Run Time: 0.000932
Run Time: 0.000316
Run Time: 0.002912
Run Time: 0.000701
Params: 0, ٻ, ٻ, XF\Pub\Controller\Forum, List, valid, , 1715217942,
Run Time: 0.001059
Params: 1715217042
Run Time: 0.000481
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 148 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1715217042)
Run Time: 0.000776
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 148 | Using where |
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1712625942)
Run Time: 0.001485
Run Time: 0.001283
Run Time: 0.001357
Run Time: 0.000317
Run Time: 0.000238
Run Time: 0.000364
Run Time: 0.000380
Run Time: 0.000247
Run Time: 0.000363
Run Time: 0.000315
Run Time: 0.001742
Run Time: 0.000239
Run Time: 0.002576
