Run Time: 0.001192
Run Time: 0.000246
Run Time: 0.000763
Run Time: 0.000335
Run Time: 0.002476
Run Time: 0.000635
Params: 0, uo, uo, XF\Pub\Controller\Forum, List, valid, , 1714642763,
Run Time: 0.001065
Params: 1714641863
Run Time: 0.000413
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 110 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1714641863)
Run Time: 0.000713
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 110 | Using where |
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1712050763)
Run Time: 0.001518
Run Time: 0.001310
Run Time: 0.001015
Run Time: 0.000288
Run Time: 0.000262
Run Time: 0.000392
Run Time: 0.000185
Run Time: 0.000325
Run Time: 0.000438
Run Time: 0.001599
Run Time: 0.002199
bytes_received | 941809 |
bytes_received_change_user_packet | 714692 |
bytes_received_real_data_ps | 702685 |
