Run Time: 0.001346
Run Time: 0.000249
Run Time: 0.000268
Run Time: 0.000710
Run Time: 0.000286
Run Time: 0.002807
Run Time: 0.000692
Params: 0, tUH, tUH, XF\Pub\Controller\Forum, List, valid, , 1714768304,
Run Time: 0.000141
Run Time: 0.000767
Params: 1714767404
Run Time: 0.000487
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 203 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1714767404)
Run Time: 0.000596
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 203 | Using where |
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1712176304)
Run Time: 0.001620
Run Time: 0.001328
Run Time: 0.000980
Run Time: 0.000328
Run Time: 0.000247
Run Time: 0.000272
Run Time: 0.000269
Run Time: 0.000384
Run Time: 0.001627
Run Time: 0.000204
Run Time: 0.002992
