Run Time: 0.001056
Run Time: 0.000751
Run Time: 0.000306
Run Time: 0.002337
Run Time: 0.000834
Params: 0, 6?, 6?, XF\Pub\Controller\Forum, List, valid, , 1715077518,
Run Time: 0.000715
Params: 1715076618
Run Time: 0.000839
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 128 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1715076618)
Run Time: 0.000670
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 128 | Using where |
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1712485518)
Run Time: 0.001659
Run Time: 0.001134
Run Time: 0.000870
Run Time: 0.000208
Run Time: 0.000312
Run Time: 0.000312
Run Time: 0.001683
Run Time: 0.000272
Run Time: 0.002066
