Run Time: 0.001283
Run Time: 0.000730
Run Time: 0.000287
Run Time: 0.002345
Run Time: 0.000521
Params: 0, t(/, t(/, XF\Pub\Controller\Forum, List, valid, , 1714284907,
Run Time: 0.000872
Params: 1714284007
Run Time: 0.000348
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 108 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1714284007)
Run Time: 0.000568
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 108 | Using where |
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1711692907)
Run Time: 0.001405
Run Time: 0.000892
Run Time: 0.000876
Run Time: 0.001423
Run Time: 0.001661
bytes_received | 941545 |
bytes_received_change_user_packet | 714428 |
bytes_received_real_data_ps | 702411 |
