Run Time: 0.001138
Run Time: 0.000732
Run Time: 0.000312
Run Time: 0.002348
Run Time: 0.000550
Params: 0, wo , wo , XF\Pub\Controller\Forum, List, valid, , 1714841549,
Run Time: 0.000132
Run Time: 0.000581
Params: 1714840649
Run Time: 0.000389
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 71 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1714840649)
Run Time: 0.000614
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 71 | Using where |
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1712249549)
Run Time: 0.001251
Run Time: 0.000980
Run Time: 0.000806
Run Time: 0.000261
Run Time: 0.001281
Run Time: 0.002099
bytes_received | 941981 |
bytes_received_change_user_packet | 714864 |
bytes_received_real_data_ps | 702829 |
