Run Time: 0.001556
Run Time: 0.000256
Run Time: 0.000280
Run Time: 0.001392
Run Time: 0.000328
Run Time: 0.004882
Run Time: 0.001056
Params: 0, ߫, ߫, XF\Pub\Controller\Forum, List, valid, , 1714767110,
Run Time: 0.000898
Params: 1714766210
Run Time: 0.000469
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 106 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1714766210)
Run Time: 0.000581
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 106 | Using where |
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1712175110)
Run Time: 0.001361
Run Time: 0.001275
Run Time: 0.001073
Run Time: 0.000359
Run Time: 0.000365
Run Time: 0.001807
Run Time: 0.002385
