Run Time: 0.001340
Run Time: 0.000768
Run Time: 0.000305
Run Time: 0.002695
Run Time: 0.000564
Params: 0, ve, ve, XF\Pub\Controller\Forum, List, valid, , 1714760748,
Run Time: 0.000127
Run Time: 0.000658
Params: 1714759848
Run Time: 0.000531
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 170 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1714759848)
Run Time: 0.000617
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 170 | Using where |
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1712168748)
Run Time: 0.001399
Run Time: 0.001071
Run Time: 0.000842
Run Time: 0.000260
Run Time: 0.000327
Run Time: 0.001623
Run Time: 0.002124
