Run Time: 0.001315
Run Time: 0.000356
Run Time: 0.001789
Run Time: 0.000382
Run Time: 0.004222
Run Time: 0.000764
Params: 0, L , L , XF\Pub\Controller\Forum, List, valid, , 1714840970,
Run Time: 0.001035
Params: 1714840070
Run Time: 0.000612
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 164 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1714840070)
Run Time: 0.000787
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 164 | Using where |
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1712248970)
Run Time: 0.002225
Run Time: 0.001291
Run Time: 0.001032
Run Time: 0.000254
Run Time: 0.000242
Run Time: 0.000335
Run Time: 0.000473
Run Time: 0.001611
Run Time: 0.000369
Run Time: 0.000356
Run Time: 0.002294
bytes_received | 941981 |
bytes_received_change_user_packet | 714864 |
bytes_received_real_data_ps | 702829 |
