Run Time: 0.001594
Run Time: 0.000674
Run Time: 0.000319
Run Time: 0.002350
Run Time: 0.000465
Params: 0, I, I, XF\Pub\Controller\Forum, List, valid, , 1714841015,
Run Time: 0.000142
Run Time: 0.001060
Params: 1714840115
Run Time: 0.000462
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 157 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1714840115)
Run Time: 0.000587
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 157 | Using where |
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1712249015)
Run Time: 0.001214
Run Time: 0.000875
Run Time: 0.000796
Run Time: 0.000254
Run Time: 0.000293
Run Time: 0.001238
Run Time: 0.000157
Run Time: 0.001955
bytes_received | 941981 |
bytes_received_change_user_packet | 714864 |
bytes_received_real_data_ps | 702829 |
