Run Time: 0.001253
Run Time: 0.000232
Run Time: 0.000218
Run Time: 0.000946
- XF\Repository\Node->getNodeList() in src/XF/Pub/Controller/Forum.php at line 52
- XF\Pub\Controller\Forum->actionList() in src/XF/Mvc/Dispatcher.php at line 350
Run Time: 0.000324
Run Time: 0.002718
Run Time: 0.000797
Params: 0, , , XF\Pub\Controller\Forum, List, valid, , 1714766017,
Run Time: 0.000167
Run Time: 0.000733
SELECT
SUM(IF(user_id >= 0 AND robot_key = '', 1, 0)) AS total,
SUM(IF(user_id > 0, 1, 0)) AS members,
SUM(IF(user_id = 0 AND robot_key = '', 1, 0)) AS guests
FROM xf_session_activity
WHERE view_date >= ?
Params: 1714765117
Run Time: 0.000678
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 159 | Using where |
- XF\Db\AbstractAdapter->query() in src/XF/Db/AbstractAdapter.php at line 145
- XF\Db\AbstractAdapter->fetchRow() in src/XF/Repository/SessionActivity.php at line 18
- XF\Repository\SessionActivity->getOnlineCounts() in src/XF/Repository/SessionActivity.php at line 62
- XF\Repository\SessionActivity->getOnlineStatsBlockData() in src/XF/Widget/MembersOnline.php at line 25
- XF\Widget\MembersOnline->render() in internal_data/code_cache/widgets/_6_forum_overview_members_online.php at line 5
- XF\Template\Templater->widgetPosition() in internal_data/code_cache/templates/l2/s6/public/forum_list.php at line 213
SELECT `xf_session_activity`.*, `xf_user_User_1`.*
INNER JOIN `xf_user` AS `xf_user_User_1` ON (`xf_user_User_1`.`user_id` = `xf_session_activity`.`user_id`)
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1714765117)
ORDER BY `xf_session_activity`.`view_date` DESC
LIMIT 50
Run Time: 0.000686
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 159 | Using where |
SIMPLE | xf_user_User_1 | eq_ref | PRIMARY,user_state | PRIMARY | 4 | muhen_fmrnd.xf_session_activity.user_id | 1 | Using where |
- XF\Mvc\Entity\Finder->fetch() in src/XF/Repository/SessionActivity.php at line 43
- XF\Repository\SessionActivity->getOnlineUsersList() in src/XF/Repository/SessionActivity.php at line 63
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1712174017)
Run Time: 0.001512
Run Time: 0.001081
SELECT `xf_profile_post`.*, `xf_user_ProfileUser_1`.*, `xf_user_privacy_Privacy_2`.*, `xf_user_User_3`.*
FROM `xf_profile_post`
LEFT JOIN `xf_user` AS `xf_user_ProfileUser_1` ON (`xf_user_ProfileUser_1`.`user_id` = `xf_profile_post`.`profile_user_id`)
LEFT JOIN `xf_user_privacy` AS `xf_user_privacy_Privacy_2` ON (`xf_user_privacy_Privacy_2`.`user_id` = `xf_user_ProfileUser_1`.`user_id`)
LEFT JOIN `xf_user` AS `xf_user_User_3` ON (`xf_user_User_3`.`user_id` = `xf_profile_post`.`user_id`)
WHERE (`xf_profile_post`.`message_state` = 'visible')
ORDER BY `xf_profile_post`.`post_date` DESC
Run Time: 0.000966
SIMPLE | xf_profile_post | ALL | | | | | 6 | Using where; Using filesort |
SIMPLE | xf_user_ProfileUser_1 | eq_ref | PRIMARY | PRIMARY | 4 | muhen_fmrnd.xf_profile_post.profile_user_id | 1 | |
SIMPLE | xf_user_privacy_Privacy_2 | eq_ref | PRIMARY | PRIMARY | 4 | muhen_fmrnd.xf_user_ProfileUser_1.user_id | 1 | Using where |
SIMPLE | xf_user_User_3 | eq_ref | PRIMARY | PRIMARY | 4 | muhen_fmrnd.xf_profile_post.user_id | 1 | |
- XF\Mvc\Entity\Finder->fetch() in src/XF/Widget/NewProfilePosts.php at line 75
- XF\Widget\NewProfilePosts->render() in internal_data/code_cache/widgets/_8_forum_overview_new_profile_posts.php at line 5
Params: 10
Run Time: 0.000315
- XF\Entity\User->hasPermission() in src/addons/XENTR/RichUsernamePlus/XF/Entity/User.php at line 15
- XENTR\RichUsernamePlus\XF\Entity\User->canChangeUsernameColor() in src/addons/XENTR/RichUsernamePlus/XF/Template/Templater.php at line 19
- XENTR\RichUsernamePlus\XF\Template\Templater->fnUsernameLink()
- XF\Template\Templater->func() in internal_data/code_cache/templates/l2/s6/public/profile_post_macros.php at line 31
- XF\Template\Templater->callMacro() in internal_data/code_cache/templates/l2/s6/public/profile_post_macros.php at line 533
- XF\Template\Templater->callMacro() in internal_data/code_cache/templates/l2/s6/public/widget_new_profile_posts.php at line 66
- XF\Template\Templater->renderTemplate() in src/XF/Widget/WidgetRenderer.php at line 62
- XF\Widget\WidgetRenderer->render() in src/XF/Widget/WidgetRenderer.php at line 67
- XF\Widget\WidgetRenderer->__toString() in src/XF/Template/Templater.php at line 1903
Run Time: 0.000262
- XF\Template\Templater->func() in internal_data/code_cache/templates/l2/s6/public/profile_post_macros.php at line 544
Params: 31
Run Time: 0.000208
- XF\Template\Templater->func() in internal_data/code_cache/templates/l2/s6/public/profile_post_macros.php at line 22
SELECT COUNT(resource_id)
FROM xf_rm_resource
Run Time: 0.000240
SIMPLE | xf_rm_resource | index | | last_update | 4 | | 226 | Using index |
- XF\Db\AbstractAdapter->fetchOne() in src/XF/Widget/ForumStatistics.php at line 14
- XF\Widget\ForumStatistics->render() in internal_data/code_cache/widgets/_9_forum_overview_forum_statistics.php at line 5
Run Time: 0.000206
- XF\App->__get() in src/XF/Widget/ForumStatistics.php at line 21
Params: 29
Run Time: 0.000345
- XF\Template\Templater->func() in internal_data/code_cache/templates/l2/s6/public/node_list_forum.php at line 286
- XF\Template\Templater->callMacro() in internal_data/code_cache/templates/l2/s6/public/node_list_forum.php at line 45
- XF\Template\Templater->callMacro() in internal_data/code_cache/templates/l2/s6/public/forum_list.php at line 25
- XF\Template\Templater->callMacro() in internal_data/code_cache/templates/l2/s6/public/forum_list.php at line 60
- XF\Template\Templater->callMacro() in internal_data/code_cache/templates/l2/s6/public/node_list_category.php at line 40
- XF\Template\Templater->callMacro() in internal_data/code_cache/templates/l2/s6/public/forum_list.php at line 227
Run Time: 0.000300
LIMIT 30
Run Time: 0.001638
- XF\Mvc\Entity\Finder->fetch() in src/addons/XenGenTr/XGTForumistatistik/Widget/YeniMesajlar.php at line 53
- XenGenTr\XGTForumistatistik\Widget\YeniMesajlar->render() in src/addons/XenGenTr/XGTForumistatistik/Entity/ForumIstatistik.php at line 52
- XenGenTr\XGTForumistatistik\Entity\ForumIstatistik->render()
- XF\Template\Templater->method() in internal_data/code_cache/templates/l2/s6/public/xgt_FrmIstatistik_icerikSonuc.php at line 7
- XF\Template\Templater->includeTemplate() in internal_data/code_cache/templates/l2/s6/public/xgt_FrmIstatistik.php at line 139
- XF\Template\Templater->renderTemplate() in src/addons/XenGenTr/XGTForumistatistik/Repository/ForumIstatistik.php at line 88
- XenGenTr\XGTForumistatistik\Repository\ForumIstatistik->renderForumIstatistikleri()
- XF\Template\Templater->method() in internal_data/code_cache/templates/l2/s6/public/xgt_FrmIstatistik_konumlar_macros.php at line 14
- XF\Template\Templater->callMacro() in internal_data/code_cache/templates/l2/s6/public/xgt_FrmIstatistik_konumlar_macros.php at line 79
- XF\Template\Templater->callMacro() in internal_data/code_cache/templates/l2/s6/public/PAGE_CONTAINER.php at line 990
Run Time: 0.000211
- XF\Template\Templater->method() in internal_data/code_cache/templates/l2/s6/public/xgt_FrmIstatistik_yeniMesajlar.php at line 31
- XF\Template\Templater->renderTemplate() in src/addons/XenGenTr/XGTForumistatistik/Widget/AbstractForumIstatistik.php at line 91
- XenGenTr\XGTForumistatistik\Widget\AbstractForumIstatistik->renderer() in src/addons/XenGenTr/XGTForumistatistik/Widget/YeniMesajlar.php at line 70
WHERE (`xf_session_activity`.`user_id` = 2307) AND (`xf_session_activity`.`unique_key` = '2307')
Run Time: 0.000236
Run Time: 0.002301
bytes_sent | 23790 |
bytes_received | 941794 |
packets_sent | 298 |
packets_received | 3477 |
protocol_overhead_in | 13908 |
protocol_overhead_out | 1192 |
bytes_received_rset_header_packet | 981 |
bytes_received_rset_row_packet | 273 |
bytes_received_prepare_response_packet | 224735 |
bytes_received_change_user_packet | 714677 |
packets_sent_command | 148 |
packets_received_rset_header | 109 |
packets_received_rset_row | 51 |
packets_received_prepare_response | 2797 |
packets_received_change_user | 469 |
non_result_set_queries | 3 |
ps_prepared_once_executed | 48 |
rows_skipped_ps | 421 |
proto_binary_fetched_bit | 2917 |
proto_binary_fetched_short | 2365 |
proto_binary_fetched_int24 | 902 |
proto_binary_fetched_bigint | 8289 |
proto_binary_fetched_decimal | 101 |
proto_binary_fetched_float | 143 |
proto_binary_fetched_json | 4405 |
proto_binary_fetched_blob | 1741 |
com_stmt_prepare | 49 |
com_stmt_execute | 49 |
com_stmt_close | 48 |
bytes_received_real_data_ps | 702670 |
