Run Time: 0.001456
Run Time: 0.000280
Run Time: 0.000245
WHERE (`xf_thread`.`thread_id` = '1293')
Run Time: 0.001137
WHERE (`xf_post`.`thread_id` = 1293) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.001041
Run Time: 0.000326
Run Time: 0.000263
Params: 1293
Run Time: 0.000098
Run Time: 0.000730
Run Time: 0.000429
Run Time: 0.002661
Run Time: 0.000567
WHERE (`xf_thread`.`title` LIKE '%Çözelti%') AND (`xf_thread`.`title` LIKE '%nedir?%') AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`post_date` >= 0) AND (`xf_thread`.`thread_id` <> 1293) AND (1) AND ((`xf_thread`.`node_id` = 3) OR (`xf_thread`.`node_id` = 4) OR (`xf_thread`.`node_id` = 5) OR (`xf_thread`.`node_id` = 6) OR (`xf_thread`.`node_id` = 7) OR (`xf_thread`.`node_id` = 114) OR (`xf_thread`.`node_id` = 16) OR (`xf_thread`.`node_id` = 17) OR (`xf_thread`.`node_id` = 18) OR (`xf_thread`.`node_id` = 115) OR (`xf_thread`.`node_id` = 57) OR (`xf_thread`.`node_id` = 19) OR (`xf_thread`.`node_id` = 40) OR (`xf_thread`.`node_id` = 47) OR (`xf_thread`.`node_id` = 116) OR (`xf_thread`.`node_id` = 41) OR (`xf_thread`.`node_id` = 94) OR (`xf_thread`.`node_id` = 45) OR (`xf_thread`.`node_id` = 46) OR (`xf_thread`.`node_id` = 44) OR (`xf_thread`.`node_id` = 43) OR (`xf_thread`.`node_id` = 42) OR (`xf_thread`.`node_id` = 95) OR (`xf_thread`.`node_id` = 96) OR (`xf_thread`.`node_id` = 97) OR (`xf_thread`.`node_id` = 26) OR (`xf_thread`.`node_id` = 30) OR (`xf_thread`.`node_id` = 27) OR (`xf_thread`.`node_id` = 28) OR (`xf_thread`.`node_id` = 29) OR (`xf_thread`.`node_id` = 98) OR (`xf_thread`.`node_id` = 99) OR (`xf_thread`.`node_id` = 100) OR (`xf_thread`.`node_id` = 101) OR (`xf_thread`.`node_id` = 102) OR (`xf_thread`.`node_id` = 103) OR (`xf_thread`.`node_id` = 37) OR (`xf_thread`.`node_id` = 39) OR (`xf_thread`.`node_id` = 38) OR (`xf_thread`.`node_id` = 104) OR (`xf_thread`.`node_id` = 105) OR (`xf_thread`.`node_id` = 106) OR (`xf_thread`.`node_id` = 31) OR (`xf_thread`.`node_id` = 48) OR (`xf_thread`.`node_id` = 107) OR (`xf_thread`.`node_id` = 108) OR (`xf_thread`.`node_id` = 23) OR (`xf_thread`.`node_id` = 109) OR (`xf_thread`.`node_id` = 110) OR (`xf_thread`.`node_id` = 111) OR (`xf_thread`.`node_id` = 112) OR (`xf_thread`.`node_id` = 51) OR (`xf_thread`.`node_id` = 34) OR (`xf_thread`.`node_id` = 60) OR (`xf_thread`.`node_id` = 61) OR (`xf_thread`.`node_id` = 66) OR (`xf_thread`.`node_id` = 62) OR (`xf_thread`.`node_id` = 63) OR (`xf_thread`.`node_id` = 64) OR (`xf_thread`.`node_id` = 65) OR (`xf_thread`.`node_id` = 67) OR (`xf_thread`.`node_id` = 70) OR (`xf_thread`.`node_id` = 71) OR (`xf_thread`.`node_id` = 72) OR (`xf_thread`.`node_id` = 73) OR (`xf_thread`.`node_id` = 74) OR (`xf_thread`.`node_id` = 75) OR (`xf_thread`.`node_id` = 76) OR (`xf_thread`.`node_id` = 77) OR (`xf_thread`.`node_id` = 78) OR (`xf_thread`.`node_id` = 79) OR (`xf_thread`.`node_id` = 80) OR (`xf_thread`.`node_id` = 81) OR (`xf_thread`.`node_id` = 82) OR (`xf_thread`.`node_id` = 83) OR (`xf_thread`.`node_id` = 84) OR (`xf_thread`.`node_id` = 85) OR (`xf_thread`.`node_id` = 86) OR (`xf_thread`.`node_id` = 87) OR (`xf_thread`.`node_id` = 88) OR (`xf_thread`.`node_id` = 89) OR (`xf_thread`.`node_id` = 90) OR (`xf_thread`.`node_id` = 91) OR (`xf_thread`.`node_id` = 92) OR (`xf_thread`.`node_id` = 93) OR (`xf_thread`.`node_id` = 54) OR (`xf_thread`.`node_id` = 55) OR (`xf_thread`.`node_id` = 58) OR (`xf_thread`.`node_id` = 59) OR (`xf_thread`.`node_id` = 56) OR (`xf_thread`.`node_id` = 113))
Run Time: 0.006604
WHERE (`xf_thread`.`title` LIKE '%Çözelti%') AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`post_date` >= 0) AND (`xf_thread`.`thread_id` <> 1293) AND (1) AND ((`xf_thread`.`node_id` = 3) OR (`xf_thread`.`node_id` = 4) OR (`xf_thread`.`node_id` = 5) OR (`xf_thread`.`node_id` = 6) OR (`xf_thread`.`node_id` = 7) OR (`xf_thread`.`node_id` = 114) OR (`xf_thread`.`node_id` = 16) OR (`xf_thread`.`node_id` = 17) OR (`xf_thread`.`node_id` = 18) OR (`xf_thread`.`node_id` = 115) OR (`xf_thread`.`node_id` = 57) OR (`xf_thread`.`node_id` = 19) OR (`xf_thread`.`node_id` = 40) OR (`xf_thread`.`node_id` = 47) OR (`xf_thread`.`node_id` = 116) OR (`xf_thread`.`node_id` = 41) OR (`xf_thread`.`node_id` = 94) OR (`xf_thread`.`node_id` = 45) OR (`xf_thread`.`node_id` = 46) OR (`xf_thread`.`node_id` = 44) OR (`xf_thread`.`node_id` = 43) OR (`xf_thread`.`node_id` = 42) OR (`xf_thread`.`node_id` = 95) OR (`xf_thread`.`node_id` = 96) OR (`xf_thread`.`node_id` = 97) OR (`xf_thread`.`node_id` = 26) OR (`xf_thread`.`node_id` = 30) OR (`xf_thread`.`node_id` = 27) OR (`xf_thread`.`node_id` = 28) OR (`xf_thread`.`node_id` = 29) OR (`xf_thread`.`node_id` = 98) OR (`xf_thread`.`node_id` = 99) OR (`xf_thread`.`node_id` = 100) OR (`xf_thread`.`node_id` = 101) OR (`xf_thread`.`node_id` = 102) OR (`xf_thread`.`node_id` = 103) OR (`xf_thread`.`node_id` = 37) OR (`xf_thread`.`node_id` = 39) OR (`xf_thread`.`node_id` = 38) OR (`xf_thread`.`node_id` = 104) OR (`xf_thread`.`node_id` = 105) OR (`xf_thread`.`node_id` = 106) OR (`xf_thread`.`node_id` = 31) OR (`xf_thread`.`node_id` = 48) OR (`xf_thread`.`node_id` = 107) OR (`xf_thread`.`node_id` = 108) OR (`xf_thread`.`node_id` = 23) OR (`xf_thread`.`node_id` = 109) OR (`xf_thread`.`node_id` = 110) OR (`xf_thread`.`node_id` = 111) OR (`xf_thread`.`node_id` = 112) OR (`xf_thread`.`node_id` = 51) OR (`xf_thread`.`node_id` = 34) OR (`xf_thread`.`node_id` = 60) OR (`xf_thread`.`node_id` = 61) OR (`xf_thread`.`node_id` = 66) OR (`xf_thread`.`node_id` = 62) OR (`xf_thread`.`node_id` = 63) OR (`xf_thread`.`node_id` = 64) OR (`xf_thread`.`node_id` = 65) OR (`xf_thread`.`node_id` = 67) OR (`xf_thread`.`node_id` = 70) OR (`xf_thread`.`node_id` = 71) OR (`xf_thread`.`node_id` = 72) OR (`xf_thread`.`node_id` = 73) OR (`xf_thread`.`node_id` = 74) OR (`xf_thread`.`node_id` = 75) OR (`xf_thread`.`node_id` = 76) OR (`xf_thread`.`node_id` = 77) OR (`xf_thread`.`node_id` = 78) OR (`xf_thread`.`node_id` = 79) OR (`xf_thread`.`node_id` = 80) OR (`xf_thread`.`node_id` = 81) OR (`xf_thread`.`node_id` = 82) OR (`xf_thread`.`node_id` = 83) OR (`xf_thread`.`node_id` = 84) OR (`xf_thread`.`node_id` = 85) OR (`xf_thread`.`node_id` = 86) OR (`xf_thread`.`node_id` = 87) OR (`xf_thread`.`node_id` = 88) OR (`xf_thread`.`node_id` = 89) OR (`xf_thread`.`node_id` = 90) OR (`xf_thread`.`node_id` = 91) OR (`xf_thread`.`node_id` = 92) OR (`xf_thread`.`node_id` = 93) OR (`xf_thread`.`node_id` = 54) OR (`xf_thread`.`node_id` = 55) OR (`xf_thread`.`node_id` = 58) OR (`xf_thread`.`node_id` = 59) OR (`xf_thread`.`node_id` = 56) OR (`xf_thread`.`node_id` = 113))
Run Time: 0.006481
WHERE (`xf_thread`.`title` LIKE '%nedir?%') AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`post_date` >= 0) AND (`xf_thread`.`thread_id` <> 1293) AND (1) AND ((`xf_thread`.`node_id` = 3) OR (`xf_thread`.`node_id` = 4) OR (`xf_thread`.`node_id` = 5) OR (`xf_thread`.`node_id` = 6) OR (`xf_thread`.`node_id` = 7) OR (`xf_thread`.`node_id` = 114) OR (`xf_thread`.`node_id` = 16) OR (`xf_thread`.`node_id` = 17) OR (`xf_thread`.`node_id` = 18) OR (`xf_thread`.`node_id` = 115) OR (`xf_thread`.`node_id` = 57) OR (`xf_thread`.`node_id` = 19) OR (`xf_thread`.`node_id` = 40) OR (`xf_thread`.`node_id` = 47) OR (`xf_thread`.`node_id` = 116) OR (`xf_thread`.`node_id` = 41) OR (`xf_thread`.`node_id` = 94) OR (`xf_thread`.`node_id` = 45) OR (`xf_thread`.`node_id` = 46) OR (`xf_thread`.`node_id` = 44) OR (`xf_thread`.`node_id` = 43) OR (`xf_thread`.`node_id` = 42) OR (`xf_thread`.`node_id` = 95) OR (`xf_thread`.`node_id` = 96) OR (`xf_thread`.`node_id` = 97) OR (`xf_thread`.`node_id` = 26) OR (`xf_thread`.`node_id` = 30) OR (`xf_thread`.`node_id` = 27) OR (`xf_thread`.`node_id` = 28) OR (`xf_thread`.`node_id` = 29) OR (`xf_thread`.`node_id` = 98) OR (`xf_thread`.`node_id` = 99) OR (`xf_thread`.`node_id` = 100) OR (`xf_thread`.`node_id` = 101) OR (`xf_thread`.`node_id` = 102) OR (`xf_thread`.`node_id` = 103) OR (`xf_thread`.`node_id` = 37) OR (`xf_thread`.`node_id` = 39) OR (`xf_thread`.`node_id` = 38) OR (`xf_thread`.`node_id` = 104) OR (`xf_thread`.`node_id` = 105) OR (`xf_thread`.`node_id` = 106) OR (`xf_thread`.`node_id` = 31) OR (`xf_thread`.`node_id` = 48) OR (`xf_thread`.`node_id` = 107) OR (`xf_thread`.`node_id` = 108) OR (`xf_thread`.`node_id` = 23) OR (`xf_thread`.`node_id` = 109) OR (`xf_thread`.`node_id` = 110) OR (`xf_thread`.`node_id` = 111) OR (`xf_thread`.`node_id` = 112) OR (`xf_thread`.`node_id` = 51) OR (`xf_thread`.`node_id` = 34) OR (`xf_thread`.`node_id` = 60) OR (`xf_thread`.`node_id` = 61) OR (`xf_thread`.`node_id` = 66) OR (`xf_thread`.`node_id` = 62) OR (`xf_thread`.`node_id` = 63) OR (`xf_thread`.`node_id` = 64) OR (`xf_thread`.`node_id` = 65) OR (`xf_thread`.`node_id` = 67) OR (`xf_thread`.`node_id` = 70) OR (`xf_thread`.`node_id` = 71) OR (`xf_thread`.`node_id` = 72) OR (`xf_thread`.`node_id` = 73) OR (`xf_thread`.`node_id` = 74) OR (`xf_thread`.`node_id` = 75) OR (`xf_thread`.`node_id` = 76) OR (`xf_thread`.`node_id` = 77) OR (`xf_thread`.`node_id` = 78) OR (`xf_thread`.`node_id` = 79) OR (`xf_thread`.`node_id` = 80) OR (`xf_thread`.`node_id` = 81) OR (`xf_thread`.`node_id` = 82) OR (`xf_thread`.`node_id` = 83) OR (`xf_thread`.`node_id` = 84) OR (`xf_thread`.`node_id` = 85) OR (`xf_thread`.`node_id` = 86) OR (`xf_thread`.`node_id` = 87) OR (`xf_thread`.`node_id` = 88) OR (`xf_thread`.`node_id` = 89) OR (`xf_thread`.`node_id` = 90) OR (`xf_thread`.`node_id` = 91) OR (`xf_thread`.`node_id` = 92) OR (`xf_thread`.`node_id` = 93) OR (`xf_thread`.`node_id` = 54) OR (`xf_thread`.`node_id` = 55) OR (`xf_thread`.`node_id` = 58) OR (`xf_thread`.`node_id` = 59) OR (`xf_thread`.`node_id` = 56) OR (`xf_thread`.`node_id` = 113))
Run Time: 0.002923
WHERE ((`xf_thread`.`thread_id` = 1365) OR (`xf_thread`.`thread_id` = 1321) OR (`xf_thread`.`thread_id` = 1305) OR (`xf_thread`.`thread_id` = 1294))
Run Time: 0.000316
Params: 0, , , XF\Pub\Controller\Thread, Index, valid, thread_id=1293, 1715206509,
Run Time: 0.000170
Run Time: 0.000754
Run Time: 0.001329
Run Time: 0.000240
Run Time: 0.000268
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1712614509)
Run Time: 0.001755
Run Time: 0.001200
Run Time: 0.000327
Run Time: 0.000309
Run Time: 0.002246
bytes_sent | 43649 |
bytes_received | 941352 |
packets_sent | 304 |
packets_received | 3659 |
protocol_overhead_in | 14636 |
bytes_received_change_user_packet | 694142 |
packets_sent_command | 151 |
packets_received_change_user | 465 |
rows_fetched_from_server_ps | 417 |
rows_buffered_from_client_ps | 417 |
rows_skipped_ps | 417 |
proto_binary_fetched_bit | 2858 |
proto_binary_fetched_short | 2208 |
proto_binary_fetched_int24 | 789 |
proto_binary_fetched_bigint | 7639 |
proto_binary_fetched_float | 120 |
proto_binary_fetched_json | 4141 |
proto_binary_fetched_blob | 1681 |
com_stmt_prepare | 50 |
com_stmt_execute | 50 |
com_stmt_close | 49 |
bytes_received_real_data_ps | 682683 |
