Run Time: 0.001315
Run Time: 0.000240
Run Time: 0.000183
WHERE (`xf_thread`.`thread_id` = '1147')
Run Time: 0.000738
WHERE (`xf_post`.`thread_id` = 1147) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.001254
SIMPLE | xf_post | ref | thread_id_post_date,thread_id_position,thread_id_score_date | thread_id_post_date | 4 | const | 3 | Using where; Using filesort |
WHERE (`xf_attachment`.`content_type` = 'post' AND `xf_attachment`.`content_id` IN (3766))
Run Time: 0.000349
Run Time: 0.000285
Run Time: 0.000253
Params: 1147
Run Time: 0.000100
Run Time: 0.000707
Run Time: 0.000282
Run Time: 0.002345
Run Time: 0.000467
WHERE (`xf_thread`.`title` LIKE '%Mikrodenetleyiciler%') AND (`xf_thread`.`title` LIKE '%Nerelerde%') AND (`xf_thread`.`title` LIKE '%Kullanılır?%') AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`post_date` >= 0) AND (`xf_thread`.`thread_id` <> 1147) AND ((`xf_thread`.`node_id` = 3) OR (`xf_thread`.`node_id` = 4) OR (`xf_thread`.`node_id` = 5) OR (`xf_thread`.`node_id` = 6) OR (`xf_thread`.`node_id` = 7) OR (`xf_thread`.`node_id` = 114) OR (`xf_thread`.`node_id` = 16) OR (`xf_thread`.`node_id` = 17) OR (`xf_thread`.`node_id` = 18) OR (`xf_thread`.`node_id` = 115) OR (`xf_thread`.`node_id` = 57) OR (`xf_thread`.`node_id` = 19) OR (`xf_thread`.`node_id` = 40) OR (`xf_thread`.`node_id` = 47) OR (`xf_thread`.`node_id` = 116) OR (`xf_thread`.`node_id` = 41) OR (`xf_thread`.`node_id` = 94) OR (`xf_thread`.`node_id` = 45) OR (`xf_thread`.`node_id` = 46) OR (`xf_thread`.`node_id` = 44) OR (`xf_thread`.`node_id` = 43) OR (`xf_thread`.`node_id` = 42) OR (`xf_thread`.`node_id` = 95) OR (`xf_thread`.`node_id` = 96) OR (`xf_thread`.`node_id` = 97) OR (`xf_thread`.`node_id` = 26) OR (`xf_thread`.`node_id` = 30) OR (`xf_thread`.`node_id` = 27) OR (`xf_thread`.`node_id` = 28) OR (`xf_thread`.`node_id` = 29) OR (`xf_thread`.`node_id` = 98) OR (`xf_thread`.`node_id` = 99) OR (`xf_thread`.`node_id` = 100) OR (`xf_thread`.`node_id` = 101) OR (`xf_thread`.`node_id` = 102) OR (`xf_thread`.`node_id` = 103) OR (`xf_thread`.`node_id` = 37) OR (`xf_thread`.`node_id` = 39) OR (`xf_thread`.`node_id` = 38) OR (`xf_thread`.`node_id` = 104) OR (`xf_thread`.`node_id` = 105) OR (`xf_thread`.`node_id` = 106) OR (`xf_thread`.`node_id` = 31) OR (`xf_thread`.`node_id` = 48) OR (`xf_thread`.`node_id` = 107) OR (`xf_thread`.`node_id` = 108) OR (`xf_thread`.`node_id` = 23) OR (`xf_thread`.`node_id` = 109) OR (`xf_thread`.`node_id` = 110) OR (`xf_thread`.`node_id` = 111) OR (`xf_thread`.`node_id` = 112) OR (`xf_thread`.`node_id` = 51) OR (`xf_thread`.`node_id` = 34) OR (`xf_thread`.`node_id` = 60) OR (`xf_thread`.`node_id` = 61) OR (`xf_thread`.`node_id` = 66) OR (`xf_thread`.`node_id` = 62) OR (`xf_thread`.`node_id` = 63) OR (`xf_thread`.`node_id` = 64) OR (`xf_thread`.`node_id` = 65) OR (`xf_thread`.`node_id` = 67) OR (`xf_thread`.`node_id` = 70) OR (`xf_thread`.`node_id` = 71) OR (`xf_thread`.`node_id` = 72) OR (`xf_thread`.`node_id` = 73) OR (`xf_thread`.`node_id` = 74) OR (`xf_thread`.`node_id` = 75) OR (`xf_thread`.`node_id` = 76) OR (`xf_thread`.`node_id` = 77) OR (`xf_thread`.`node_id` = 78) OR (`xf_thread`.`node_id` = 79) OR (`xf_thread`.`node_id` = 80) OR (`xf_thread`.`node_id` = 81) OR (`xf_thread`.`node_id` = 82) OR (`xf_thread`.`node_id` = 83) OR (`xf_thread`.`node_id` = 84) OR (`xf_thread`.`node_id` = 85) OR (`xf_thread`.`node_id` = 86) OR (`xf_thread`.`node_id` = 87) OR (`xf_thread`.`node_id` = 88) OR (`xf_thread`.`node_id` = 89) OR (`xf_thread`.`node_id` = 90) OR (`xf_thread`.`node_id` = 91) OR (`xf_thread`.`node_id` = 92) OR (`xf_thread`.`node_id` = 93) OR (`xf_thread`.`node_id` = 54) OR (`xf_thread`.`node_id` = 55) OR (`xf_thread`.`node_id` = 58) OR (`xf_thread`.`node_id` = 59) OR (`xf_thread`.`node_id` = 56) OR (`xf_thread`.`node_id` = 113))
Run Time: 0.006664
WHERE (`xf_thread`.`title` LIKE '%Mikrodenetleyiciler%') AND (`xf_thread`.`title` LIKE '%Nerelerde%') AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`post_date` >= 0) AND (`xf_thread`.`thread_id` <> 1147) AND (1) AND ((`xf_thread`.`node_id` = 3) OR (`xf_thread`.`node_id` = 4) OR (`xf_thread`.`node_id` = 5) OR (`xf_thread`.`node_id` = 6) OR (`xf_thread`.`node_id` = 7) OR (`xf_thread`.`node_id` = 114) OR (`xf_thread`.`node_id` = 16) OR (`xf_thread`.`node_id` = 17) OR (`xf_thread`.`node_id` = 18) OR (`xf_thread`.`node_id` = 115) OR (`xf_thread`.`node_id` = 57) OR (`xf_thread`.`node_id` = 19) OR (`xf_thread`.`node_id` = 40) OR (`xf_thread`.`node_id` = 47) OR (`xf_thread`.`node_id` = 116) OR (`xf_thread`.`node_id` = 41) OR (`xf_thread`.`node_id` = 94) OR (`xf_thread`.`node_id` = 45) OR (`xf_thread`.`node_id` = 46) OR (`xf_thread`.`node_id` = 44) OR (`xf_thread`.`node_id` = 43) OR (`xf_thread`.`node_id` = 42) OR (`xf_thread`.`node_id` = 95) OR (`xf_thread`.`node_id` = 96) OR (`xf_thread`.`node_id` = 97) OR (`xf_thread`.`node_id` = 26) OR (`xf_thread`.`node_id` = 30) OR (`xf_thread`.`node_id` = 27) OR (`xf_thread`.`node_id` = 28) OR (`xf_thread`.`node_id` = 29) OR (`xf_thread`.`node_id` = 98) OR (`xf_thread`.`node_id` = 99) OR (`xf_thread`.`node_id` = 100) OR (`xf_thread`.`node_id` = 101) OR (`xf_thread`.`node_id` = 102) OR (`xf_thread`.`node_id` = 103) OR (`xf_thread`.`node_id` = 37) OR (`xf_thread`.`node_id` = 39) OR (`xf_thread`.`node_id` = 38) OR (`xf_thread`.`node_id` = 104) OR (`xf_thread`.`node_id` = 105) OR (`xf_thread`.`node_id` = 106) OR (`xf_thread`.`node_id` = 31) OR (`xf_thread`.`node_id` = 48) OR (`xf_thread`.`node_id` = 107) OR (`xf_thread`.`node_id` = 108) OR (`xf_thread`.`node_id` = 23) OR (`xf_thread`.`node_id` = 109) OR (`xf_thread`.`node_id` = 110) OR (`xf_thread`.`node_id` = 111) OR (`xf_thread`.`node_id` = 112) OR (`xf_thread`.`node_id` = 51) OR (`xf_thread`.`node_id` = 34) OR (`xf_thread`.`node_id` = 60) OR (`xf_thread`.`node_id` = 61) OR (`xf_thread`.`node_id` = 66) OR (`xf_thread`.`node_id` = 62) OR (`xf_thread`.`node_id` = 63) OR (`xf_thread`.`node_id` = 64) OR (`xf_thread`.`node_id` = 65) OR (`xf_thread`.`node_id` = 67) OR (`xf_thread`.`node_id` = 70) OR (`xf_thread`.`node_id` = 71) OR (`xf_thread`.`node_id` = 72) OR (`xf_thread`.`node_id` = 73) OR (`xf_thread`.`node_id` = 74) OR (`xf_thread`.`node_id` = 75) OR (`xf_thread`.`node_id` = 76) OR (`xf_thread`.`node_id` = 77) OR (`xf_thread`.`node_id` = 78) OR (`xf_thread`.`node_id` = 79) OR (`xf_thread`.`node_id` = 80) OR (`xf_thread`.`node_id` = 81) OR (`xf_thread`.`node_id` = 82) OR (`xf_thread`.`node_id` = 83) OR (`xf_thread`.`node_id` = 84) OR (`xf_thread`.`node_id` = 85) OR (`xf_thread`.`node_id` = 86) OR (`xf_thread`.`node_id` = 87) OR (`xf_thread`.`node_id` = 88) OR (`xf_thread`.`node_id` = 89) OR (`xf_thread`.`node_id` = 90) OR (`xf_thread`.`node_id` = 91) OR (`xf_thread`.`node_id` = 92) OR (`xf_thread`.`node_id` = 93) OR (`xf_thread`.`node_id` = 54) OR (`xf_thread`.`node_id` = 55) OR (`xf_thread`.`node_id` = 58) OR (`xf_thread`.`node_id` = 59) OR (`xf_thread`.`node_id` = 56) OR (`xf_thread`.`node_id` = 113))
Run Time: 0.006449
WHERE (`xf_thread`.`title` LIKE '%Mikrodenetleyiciler%') AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`post_date` >= 0) AND (`xf_thread`.`thread_id` <> 1147) AND (1) AND ((`xf_thread`.`node_id` = 3) OR (`xf_thread`.`node_id` = 4) OR (`xf_thread`.`node_id` = 5) OR (`xf_thread`.`node_id` = 6) OR (`xf_thread`.`node_id` = 7) OR (`xf_thread`.`node_id` = 114) OR (`xf_thread`.`node_id` = 16) OR (`xf_thread`.`node_id` = 17) OR (`xf_thread`.`node_id` = 18) OR (`xf_thread`.`node_id` = 115) OR (`xf_thread`.`node_id` = 57) OR (`xf_thread`.`node_id` = 19) OR (`xf_thread`.`node_id` = 40) OR (`xf_thread`.`node_id` = 47) OR (`xf_thread`.`node_id` = 116) OR (`xf_thread`.`node_id` = 41) OR (`xf_thread`.`node_id` = 94) OR (`xf_thread`.`node_id` = 45) OR (`xf_thread`.`node_id` = 46) OR (`xf_thread`.`node_id` = 44) OR (`xf_thread`.`node_id` = 43) OR (`xf_thread`.`node_id` = 42) OR (`xf_thread`.`node_id` = 95) OR (`xf_thread`.`node_id` = 96) OR (`xf_thread`.`node_id` = 97) OR (`xf_thread`.`node_id` = 26) OR (`xf_thread`.`node_id` = 30) OR (`xf_thread`.`node_id` = 27) OR (`xf_thread`.`node_id` = 28) OR (`xf_thread`.`node_id` = 29) OR (`xf_thread`.`node_id` = 98) OR (`xf_thread`.`node_id` = 99) OR (`xf_thread`.`node_id` = 100) OR (`xf_thread`.`node_id` = 101) OR (`xf_thread`.`node_id` = 102) OR (`xf_thread`.`node_id` = 103) OR (`xf_thread`.`node_id` = 37) OR (`xf_thread`.`node_id` = 39) OR (`xf_thread`.`node_id` = 38) OR (`xf_thread`.`node_id` = 104) OR (`xf_thread`.`node_id` = 105) OR (`xf_thread`.`node_id` = 106) OR (`xf_thread`.`node_id` = 31) OR (`xf_thread`.`node_id` = 48) OR (`xf_thread`.`node_id` = 107) OR (`xf_thread`.`node_id` = 108) OR (`xf_thread`.`node_id` = 23) OR (`xf_thread`.`node_id` = 109) OR (`xf_thread`.`node_id` = 110) OR (`xf_thread`.`node_id` = 111) OR (`xf_thread`.`node_id` = 112) OR (`xf_thread`.`node_id` = 51) OR (`xf_thread`.`node_id` = 34) OR (`xf_thread`.`node_id` = 60) OR (`xf_thread`.`node_id` = 61) OR (`xf_thread`.`node_id` = 66) OR (`xf_thread`.`node_id` = 62) OR (`xf_thread`.`node_id` = 63) OR (`xf_thread`.`node_id` = 64) OR (`xf_thread`.`node_id` = 65) OR (`xf_thread`.`node_id` = 67) OR (`xf_thread`.`node_id` = 70) OR (`xf_thread`.`node_id` = 71) OR (`xf_thread`.`node_id` = 72) OR (`xf_thread`.`node_id` = 73) OR (`xf_thread`.`node_id` = 74) OR (`xf_thread`.`node_id` = 75) OR (`xf_thread`.`node_id` = 76) OR (`xf_thread`.`node_id` = 77) OR (`xf_thread`.`node_id` = 78) OR (`xf_thread`.`node_id` = 79) OR (`xf_thread`.`node_id` = 80) OR (`xf_thread`.`node_id` = 81) OR (`xf_thread`.`node_id` = 82) OR (`xf_thread`.`node_id` = 83) OR (`xf_thread`.`node_id` = 84) OR (`xf_thread`.`node_id` = 85) OR (`xf_thread`.`node_id` = 86) OR (`xf_thread`.`node_id` = 87) OR (`xf_thread`.`node_id` = 88) OR (`xf_thread`.`node_id` = 89) OR (`xf_thread`.`node_id` = 90) OR (`xf_thread`.`node_id` = 91) OR (`xf_thread`.`node_id` = 92) OR (`xf_thread`.`node_id` = 93) OR (`xf_thread`.`node_id` = 54) OR (`xf_thread`.`node_id` = 55) OR (`xf_thread`.`node_id` = 58) OR (`xf_thread`.`node_id` = 59) OR (`xf_thread`.`node_id` = 56) OR (`xf_thread`.`node_id` = 113))
Run Time: 0.006389
WHERE (`xf_thread`.`title` LIKE '%Nerelerde%') AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`post_date` >= 0) AND (`xf_thread`.`thread_id` <> 1147) AND (1) AND ((`xf_thread`.`node_id` = 3) OR (`xf_thread`.`node_id` = 4) OR (`xf_thread`.`node_id` = 5) OR (`xf_thread`.`node_id` = 6) OR (`xf_thread`.`node_id` = 7) OR (`xf_thread`.`node_id` = 114) OR (`xf_thread`.`node_id` = 16) OR (`xf_thread`.`node_id` = 17) OR (`xf_thread`.`node_id` = 18) OR (`xf_thread`.`node_id` = 115) OR (`xf_thread`.`node_id` = 57) OR (`xf_thread`.`node_id` = 19) OR (`xf_thread`.`node_id` = 40) OR (`xf_thread`.`node_id` = 47) OR (`xf_thread`.`node_id` = 116) OR (`xf_thread`.`node_id` = 41) OR (`xf_thread`.`node_id` = 94) OR (`xf_thread`.`node_id` = 45) OR (`xf_thread`.`node_id` = 46) OR (`xf_thread`.`node_id` = 44) OR (`xf_thread`.`node_id` = 43) OR (`xf_thread`.`node_id` = 42) OR (`xf_thread`.`node_id` = 95) OR (`xf_thread`.`node_id` = 96) OR (`xf_thread`.`node_id` = 97) OR (`xf_thread`.`node_id` = 26) OR (`xf_thread`.`node_id` = 30) OR (`xf_thread`.`node_id` = 27) OR (`xf_thread`.`node_id` = 28) OR (`xf_thread`.`node_id` = 29) OR (`xf_thread`.`node_id` = 98) OR (`xf_thread`.`node_id` = 99) OR (`xf_thread`.`node_id` = 100) OR (`xf_thread`.`node_id` = 101) OR (`xf_thread`.`node_id` = 102) OR (`xf_thread`.`node_id` = 103) OR (`xf_thread`.`node_id` = 37) OR (`xf_thread`.`node_id` = 39) OR (`xf_thread`.`node_id` = 38) OR (`xf_thread`.`node_id` = 104) OR (`xf_thread`.`node_id` = 105) OR (`xf_thread`.`node_id` = 106) OR (`xf_thread`.`node_id` = 31) OR (`xf_thread`.`node_id` = 48) OR (`xf_thread`.`node_id` = 107) OR (`xf_thread`.`node_id` = 108) OR (`xf_thread`.`node_id` = 23) OR (`xf_thread`.`node_id` = 109) OR (`xf_thread`.`node_id` = 110) OR (`xf_thread`.`node_id` = 111) OR (`xf_thread`.`node_id` = 112) OR (`xf_thread`.`node_id` = 51) OR (`xf_thread`.`node_id` = 34) OR (`xf_thread`.`node_id` = 60) OR (`xf_thread`.`node_id` = 61) OR (`xf_thread`.`node_id` = 66) OR (`xf_thread`.`node_id` = 62) OR (`xf_thread`.`node_id` = 63) OR (`xf_thread`.`node_id` = 64) OR (`xf_thread`.`node_id` = 65) OR (`xf_thread`.`node_id` = 67) OR (`xf_thread`.`node_id` = 70) OR (`xf_thread`.`node_id` = 71) OR (`xf_thread`.`node_id` = 72) OR (`xf_thread`.`node_id` = 73) OR (`xf_thread`.`node_id` = 74) OR (`xf_thread`.`node_id` = 75) OR (`xf_thread`.`node_id` = 76) OR (`xf_thread`.`node_id` = 77) OR (`xf_thread`.`node_id` = 78) OR (`xf_thread`.`node_id` = 79) OR (`xf_thread`.`node_id` = 80) OR (`xf_thread`.`node_id` = 81) OR (`xf_thread`.`node_id` = 82) OR (`xf_thread`.`node_id` = 83) OR (`xf_thread`.`node_id` = 84) OR (`xf_thread`.`node_id` = 85) OR (`xf_thread`.`node_id` = 86) OR (`xf_thread`.`node_id` = 87) OR (`xf_thread`.`node_id` = 88) OR (`xf_thread`.`node_id` = 89) OR (`xf_thread`.`node_id` = 90) OR (`xf_thread`.`node_id` = 91) OR (`xf_thread`.`node_id` = 92) OR (`xf_thread`.`node_id` = 93) OR (`xf_thread`.`node_id` = 54) OR (`xf_thread`.`node_id` = 55) OR (`xf_thread`.`node_id` = 58) OR (`xf_thread`.`node_id` = 59) OR (`xf_thread`.`node_id` = 56) OR (`xf_thread`.`node_id` = 113))
Run Time: 0.006402
WHERE ((`xf_thread`.`thread_id` = 1385) OR (`xf_thread`.`thread_id` = 779) OR (`xf_thread`.`thread_id` = 741) OR (`xf_thread`.`thread_id` = 24))
Run Time: 0.000284
Params: 0, , , XF\Pub\Controller\Thread, Index, valid, thread_id=1147, 1716191324,
Run Time: 0.000151
Run Time: 0.000667
Run Time: 0.001096
Run Time: 0.000196
Run Time: 0.000220
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1713599324)
Run Time: 0.001302
Run Time: 0.000918
Run Time: 0.000227
Run Time: 0.000288
Run Time: 0.001824
bytes_sent | 51367 |
bytes_received | 969348 |
packets_received | 3821 |
protocol_overhead_in | 15284 |
bytes_received_rset_header_packet | 990 |
bytes_received_prepare_response_packet | 254130 |
bytes_received_change_user_packet | 712696 |
packets_received_rset_header | 110 |
packets_received_prepare_response | 3122 |
packets_received_change_user | 477 |
rows_fetched_from_server_ps | 425 |
rows_buffered_from_client_ps | 425 |
rows_skipped_ps | 425 |
proto_binary_fetched_bit | 2913 |
proto_binary_fetched_short | 2297 |
proto_binary_fetched_int24 | 827 |
proto_binary_fetched_bigint | 7938 |
proto_binary_fetched_decimal | 112 |
proto_binary_fetched_float | 126 |
proto_binary_fetched_json | 4291 |
proto_binary_fetched_blob | 1739 |
bytes_received_real_data_ps | 700862 |
