ORS Rulman Kataloğu
Sayfa: « Önceki  1, 2, 3 ... 20, 21, 22, 23  Sonraki » | Hepsini Gör
    Makine
Üye No: 24035
Kayıt: 18.02.2013
Puan: 1
Şehir: Kayseri
MesajTarih: 5/3/2013, 15:16    Mesaj konusu: Alıntıyla Cevap Gönder
emek verenlere teşekkürler
Üye No: 23434
Kayıt: 27.11.2012
Puan: 2
Şehir: İzmir
MesajTarih: 17/3/2013, 17:57    Mesaj konusu: Alıntıyla Cevap Gönder
teşekkür ederim:)
Üye No: 5204
Kayıt: 20.04.2007
Şehir: samsun
MesajTarih: 17/9/2013, 12:41    Mesaj konusu: Alıntıyla Cevap Gönder
çok teşekkür ederim.çok aradım sağolasın
Üye No: 18
Kayıt: 17.10.2006
Puan: 116
Şehir: Zonguldak
MesajTarih: 17/9/2013, 14:20    Mesaj konusu: Alıntıyla Cevap Gönder
The FAG rolling bearing programme . . . . . . . . . . . . . . . 3
Rolling bearing types . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4
Rolling bearing components . . . . . . . . . . . . . . . . . . . . . . 5
Rolling elements . . . . . . . . . . . . . . . . . . . . . . . . . . 5
Bearing rings . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6
Cages . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6
Load ratings . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8
Combined load . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8
Dimensioning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9
Statically stressed bearings . . . . . . . . . . . . . . . . . . 9
Service life . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9
Wear . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9
Dynamically stressed bearings . . . . . . . . . . . . . . . 10
Nominal rating life . . . . . . . . . . . . . . . . . . . . . . . . 11
Adjusted rating life calculation . . . . . . . . . . . . . . . 12
Lubrication . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 17
Grease lubrication . . . . . . . . . . . . . . . . . . . . . . . . . 17
Oil lubrication . . . . . . . . . . . . . . . . . . . . . . . . . . . 17
Important rolling bearing lubrication terms . . . . 17
Seals . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 21
Speed suitability . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 22
High temperature suitability . . . . . . . . . . . . . . . . . . . . . . 23
Bearing clearance . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 24
Tolerances . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 26
Alignment . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 27
Fits . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 28
Bearing arrangement . . . . . . . . . . . . . . . . . . . . . . . . . . . . 29
Symbols for load carrying capacity, alignment
and speed suitability . . . . . . . . . . . . . . . . . . . . . . . 32
Deep groove ball bearings . . . . . . . . . . . . . . . . . . . . . . . . 33
Angular contact ball bearings, single row . . . . . . . . . . . . . 34
Angular contact ball bearings, double row . . . . . . . . . . . . 35
Four-point bearings . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 36
Self-aligning ball bearings . . . . . . . . . . . . . . . . . . . . . . . . 37
Cylindrical roller bearings . . . . . . . . . . . . . . . . . . . . . . . . 38
Needle roller bearings . . . . . . . . . . . . . . . . . . . . . . . . . . . . 40
Tapered roller bearings . . . . . . . . . . . . . . . . . . . . . . . . . . . 41
Barrel roller bearings . . . . . . . . . . . . . . . . . . . . . . . . . . . . 43
Spherical roller bearings . . . . . . . . . . . . . . . . . . . . . . . . . . 44
Thrust ball bearings . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 46
Angular contact thrust ball bearings . . . . . . . . . . . . . . . . 47
Cylindrical roller thrust bearings . . . . . . . . . . . . . . . . . . . 48
Spherical roller thrust bearings . . . . . . . . . . . . . . . . . . . . . 49
Matched rolling bearings . . . . . . . . . . . . . . . . . . . . . . . . . 50
Bearing units . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 51
Checklist for rolling bearing determination . . . . . . . . . . 53
Index . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 54
Introduction
This Technical Information contains a summary of fundamental knowledge of FAG rolling bearings and should serve as
an introduction to rolling bearing engineering. It is intended
for those who have little or no knowledge of rolling bearings.
If you should like to enlarge your fundamental knowledge at
your PC, we recommend you to use our rolling bearing learning system W.L.S.(cp. also Publ. No. WL 00106).
The FAG catalogue WL 41520 "FAG Rolling Bearings" is
frequently referred to in this publication. It provides all the
essential data designers need to safely and economically design
all standard rolling bearings.
The FAG rolling bearing catalogue on CD-ROMoutshines
the usual software catalogues, being a comfortable, electronic
consulting system. In a dialogue with WINDOWS you can
quickly select the right FAG rolling bearing for your application and accurately calculate its life, speed, friction, temperature and cycling frequencies. This will save you a lot of money
and time.
A large number of technical publications is available for specific applications which you can order from us indicating the
publication number.
Rolling bearing codes are explained in detail in our Technical
Information WL 43-1191.
Key rolling bearing engineering terms appear in boldface and
will be explained in more detail (see also
Üye No: 23860
Kayıt: 19.01.2013
Puan: 6
Şehir: ankara
MesajTarih: 3/10/2013, 11:48    Mesaj konusu: Alıntıyla Cevap Gönder
iyi paylaşım
    Makine
Yeni mesaj yok Önemli: skf rulman kataloğu alaaddinyorulmaz Makine 7 5/1/2016, 12:51 Son gönderilen mesajlar
herakles
Yeni mesaj yok Önemli: AUTOCAD 2D-3D RULMAN YATAK ÇİZİMLERİ huso Çizimleriniz(sadece makineciler,autocad) 6 7/6/2016, 12:45 Son gönderilen mesajlar
xzorrox
Yeni mesaj yok Önemli: AutoCAd (Ders02) Rulman çizimi görsel... c33 Autocad Görsel Derslerimiz 2 8/12/2013, 15:45 Son gönderilen mesajlar
esra1107
Yeni mesaj yok Fag rulman kataloğu silistre Makine 18 8/1/2016, 15:04 Son gönderilen mesajlar
markasyan
Yeni mesaj yok Autocad rulman çizimi, rulman ve bika... murat6790 Çizimleriniz(sadece makineciler,autocad) 0 25/12/2009, 21:12 Son gönderilen mesajlar
murat6790
Yeni mesaj yok Asansör Kataloğu demird Asansör Sistemleri/Projeleri 0 10/12/2014, 23:49 Son gönderilen mesajlar
demird
Yeni mesaj yok Transistör Kataloğu isuldur Sensör/Transistör/Röle .vb 0 29/5/2009, 14:36 Son gönderilen mesajlar
isuldur
Yeni mesaj yok intermotor kataloğu alfabahadirr Ders notları/Föyler/Lab.lar(makine müh) 0 22/9/2015, 20:42 Son gönderilen mesajlar
alfabahadirr
Yeni mesaj yok Kesici Uç Kataloğu Tamer Cnc-Torna ..vb tezgahlar(Talaşlı im.) 2 25/3/2009, 22:14 Son gönderilen mesajlar
aabanozcu
Yeni mesaj yok WILO Pompa Kataloğu KeeReeM Hidrolik & Pnömatik &Pompalar 2 10/5/2009, 14:42 Son gönderilen mesajlar
miramax
Kod Çalışma Süresi = 0.0496 saniye, SQL Sorgu Adedi = 28, GZIP = Kapalı Hata denetimi = Kapalı,
140331 Saldırı girişimi engellendi
