Engineering Analysis with COSMOSWorks 2005
Sayfa: « Önceki  1, 2, 3, 4, 5, 6, 7, 8  Sonraki » | Hepsini Gör
    CosmosWorks
Banlandı
Banlandı
Üye No: 10132
Kayıt: 29.08.2007
Şehir: istanbull
MesajTarih: 4/2/2009, 22:45    Mesaj konusu: Alıntıyla Cevap Gönder
teşekkürler
Üye No: 18969
Kayıt: 24.02.2009
Şehir: sakarya
MesajTarih: 2/3/2009, 09:43    Mesaj konusu: Alıntıyla Cevap Gönder
ÇOK TEŞEKÜR EDERİM
Kullanıcı bilgilerini göster Kişisel mesaj gönder E-Posta gönder Kullanıcının web sitesini ziyaret et
Üye No: 15861
Kayıt: 07.12.2007
Şehir: manisa
MesajTarih: 24/3/2009, 17:17    Mesaj konusu: Alıntıyla Cevap Gönder
saol arkadaşım.
Kullanıcı bilgilerini göster Kişisel mesaj gönder E-Posta gönder MSNM
Co.Admin
Co.Admin
Üye No: 92
Kayıt: 05.11.2006
Puan: 1898
MesajTarih: 24/3/2009, 22:32    Mesaj konusu: Engineering Analysis with COSMOSWorks 2005 Alıntıyla Cevap Gönder
100 lerce sayfa pdf harika bir kaynak .
Table of contents
Before You Start 1
Notes on hands-on exercises
Prerequisites
Windows XP terminology
1: Introduction 3
What is Finite Element Analysis?
Who should use Finite Element Analysis?
Objectives of FEA for Design Engineers
What is COSMOSWorks?
Fundamental steps in an FEA project
Errors in FEA
A closer look at finite elements
What is calculated in FEA?
How to interpret FEA results
Units of measurements
Using on-line help
Limitations of COSMOSWorks Professional
2: Static analysis of a plate 25
Using COSMOSWorks interface
Linear static analysis with solid elements
The influence of mesh density on displacement and stress results
Controlling discretization errors by the convergence process
Presenting FEA results in desired format
Finding reaction forces
in
Finite Element Analysis with COSMOSWorks
3: Static analysis of an L-bracket 61
Stress singularities
Differences between modeling errors and discretization errors
Using mesh controls
Analysis in different SolidWorks configurations
4: Frequency analysis of a thin plate with shell elements 75
Use of shell elements for analysis of thin walled structures
Frequency analysis
5: Static analysis of a link 91
Symmetry boundary conditions
Defining restraints in a local coordinate system
Preventing rigid body motions
Limitations of small displacements theory
6: Frequency analysis of a tuning fork 99
Frequency analysis with and without supports
Rigid body modes
The role of supports in frequency analysis
7: Thermal analysis of a pipeline component 105
Steady state thermal analysis
Analogies between structural and thermal analysis
Analysis of temperature distribution and heat flux
8: Thermal analysis of a heat sink 113
Analysis of an assembly
Global and local Contact/Gaps conditions
Transient thermal analysis
Thermal resistance layer
Use of section views in results plots
IV
Using mesh controls
Frequency analysis
Rigid body modes
IV
9: Static analysis of a hanger 127
Analysis of assembly
Hierarchy of Contact/Gaps conditions
10: Analysis of contact stress between two plates 139
Assembly analysis with surface contact conditions
Contact stress analysis
Avoiding rigid body modes
11: Thermal stress analysis of a bi-metal beam 145
Thermal stress analysis of an assembly
Use of various techniques in defining restraints
Shear stress analysis
12: Buckling analysis of an L-beam 153
Buckling analysis
Buckling load safety factor
Stress safety factor
13: Design optimization of a plate in bending 157
Structural optimization analysis
Optimization goal
Optimization constraints
Design variables
14: Static analysis of a bracket using p-elcments 169
P-elements
P-adaptive solution method
Comparison between h-elements and p-elements
v
15: Design sensitivity analysis 179
Design sensitivity analysis using Design Scenario
16: Drop test of a coffee mug 1S7
Drop test analysis
Stress wave propagation
Direct time integration solution
17: Miscellaneous topics 195
Selecting the automesher
Solvers and solvers options
Displaying mesh in result plots
Automatic reports
E drawings
Non uniform loads
Bearing load
Frequency analysis with pre-stress
Large deformation analysis
Shrink fit analysis
Rigid connector
Üye No: 18499
Kayıt: 14.01.2009
Şehir: İstanbul
MesajTarih: 26/3/2009, 11:54    Mesaj konusu: Teşekkürler Alıntıyla Cevap Gönder
Teşekkürler arkadaşım
    CosmosWorks
Yeni mesaj yok Duyuru: COSMOSWORKS ADINA HERŞEY (TÜRKÇE ) 26 MB serthan CosmosWorks 1 15/10/2008, 13:02 Son gönderilen mesajlar
Yeni mesaj yok Önemli: Cosmosworks Türkçe Eğitim notları huso CosmosWorks 13 15/1/2011, 17:25 Son gönderilen mesajlar
miramax
Yeni mesaj yok Önemli: Visual C#.NET 2005 Ders Notları silistre VB/C,C++,/Fortran 3 3/12/2013, 13:39 Son gönderilen mesajlar
hcozalp
Yeni mesaj yok Önemli: Visual Studio .Net 2005 Express Edition mahrocan Asp.NET/C#/VB.NET 4 13/3/2007, 18:06 Son gönderilen mesajlar
silistre
Yeni mesaj yok Önemli: Electric Circuit Analysis Using MATLAB huso Matlab/Mathematica 46 2/5/2018, 14:28 Son gönderilen mesajlar
yedurgun
Bu başlık kilitlenmiştir; cevap yazamaz, mesajları değiştiremezsiniz Önemli: CIVIL ENGINEERING ebooks huso İnsaat Mühendisleri/Mimarlar 1 26/5/2009, 16:25 Son gönderilen mesajlar
Yeni mesaj yok Önemli: The Mechanical Engineering Handbook dhersimly Makine 112 6/9/2017, 02:13 Son gönderilen mesajlar
Makineer
Yeni mesaj yok Cosmosworks Tips and Tricks / Introdu... torlak CosmosWorks 0 15/10/2009, 01:02 Son gönderilen mesajlar
torlak
Yeni mesaj yok Engineering Analysis with ANSYS huso ANSYS 2 6/2/2014, 19:25 Son gönderilen mesajlar
hcozalp
Yeni mesaj yok Engineering Analysis with ANSYS Software huso ANSYS 1 14/6/2009, 00:21 Son gönderilen mesajlar
Kod Çalışma Süresi = 0.0552 saniye, SQL Sorgu Adedi = 27, GZIP = Kapalı Hata denetimi = Kapalı,
138655 Saldırı girişimi engellendi
