Perl Programlama Eğitim CD
Sayfa: 1, 2  Sonraki » | Hepsini Gör
    PHP/ASP/HTML/CGI/JAVA/PYTHON
Kıdemli Üye
Kıdemli Üye
Üye No: 12
Kayıt: 14.10.2006
Puan: 10
Şehir: istanbul
MesajTarih: 25/6/2007, 01:08    Mesaj konusu: Perl Programlama Eğitim CD Alıntıyla Cevap Gönder
Linux CBT Scripting Edition - Perl Scripting
Not : Eğitim dili ingilizcedir.Video eğitimdir
[Linki görmek için üye olmanız gerekmektedir]
Practical Extraction & Reporting Language (Perl)
Basics
Discuss Perl’s capabilities
Identify available Perl binaries on the system
Discuss Perldoc - documentation program
Discuss Perl interpreter
Define first Perl program - Hello World
Explain the application of the SHEBANG header within Perl scripts
Explain warnings options
Explain strict options
Discuss compilation of Perl scripts and compare and contrast with shell scripts
Comments
Print function
Escape sequences including (\t, \n, etc.)
Explain quoting rules and variable interpolation
Variable definition
Operators
Perl Variables
Variable scopes (Global/Local)
Scalars - single values
Discuss the properties of scalar variables
Evaluate the definition of scalars
Variable concatenation
Arrays - lists & lists of lists
Discuss the properties of array variables
Evaluate the definition of arrays
Multi-dimensional arrays
Array slices
Array functions
Ranges
Hashes - Key/Value pairs
Discuss the properties of hashes
Evaluate the definition of hashes
Control Structures
Discuss various types of Subroutines and features
Define non-returning sub-routines
Define returning sub-routine
Conditionals
If - integer and string comparisons
Else/elsif testing
Unless
For Loops
Foreach Loops - Array iteration
While Loops
Until Loops
General Perl Information I
Block Definition
Use the X Functions for file system testing
Positional parameters - ARGV
Determine number of command line arguments
Record Separators
Internal Perl Variables
Modules
Explore the module path and applicable variables
Discuss various ways to install Perl modules
Install modules
File I/O
File Handles
Open Function
Discuss rules regarding file handles and use of the open function
Assign file handles to Perl arrays for iteration
Process text files using applicable file I/O functions and foreach loops
Generate data files using file I/O functions
Die function
Error handing with Perl’s built-in variables
Count records from input file
Use the Split function to separate fields based on various delimiters
Use Join to assemble lists
General Perl Information II
References
Chomp - strip superfluous characters
Command substitution
Use execute function to launch external programs
Use system function to execute external commands and evaluate return status
Regular Expressions discussion
Demonstrate the many rules of Regular Expressions
Process arrays using push/pop functions
Generated data files and process them using split and field determination
Mail integration using Sendmail
Mail integration using downloaded Perl mail module
Define and execute Perl one-liners
Common Gateway Interface (CGI) - Apache 2.x integration
Process GET & POST variables
MySQL Database integration
Identify required modules for MySQL integration
Define connection object
Execute SELECT queries
Execute INSERT queries
Execute UPDATE queries
Execute DELETE queries
Bu sunumu sitemize atan üyemizin hesabına (ftp'den..) 350 puan geçirelecktir.
İletişim icin;
Müteşekkir Olan Üyeler
1 bu mesaj sahibine müteşekkir oldular.
Uploader
Üye No: 9436
Kayıt: 18.08.2007
Puan: 10
Şehir: LosAngeles-Sydney
MesajTarih: 13/10/2007, 00:56    Mesaj konusu: Alıntıyla Cevap Gönder
Perl eğitimi artık server larımızdadır.
Eğtim Türü : Video
Eğitim Dili : İngilizce
part1 (dahil) - part6 (dahil) arası : 48,829 mb
part7 : 8,538 mb
toplam boyut :
sıkıştırılmış (rar) hali : 294 mb
açılmış hali : 315 mb
linkler :
Bu uygulama üyelerin foruma katılımını sağlamak içindir...
''aa,asdas,iii...vb gibi anlamsız mesajların uyeliginize mal olabilecegini unutmamalisiniz,sizden beklenen sadece memnuniyet ifadesi!
herkese iyi çalışmalar.
Kullanıcı bilgilerini göster Kişisel mesaj gönder E-Posta gönder Kullanıcının web sitesini ziyaret et
Misafir
Durum:
MesajTarih: 19/11/2007, 16:57    Mesaj konusu: Alıntıyla Cevap Gönder
çok saol dost
Uploader
Üye No: 7083
Kayıt: 30.06.2007
Şehir: ist
MesajTarih: 20/11/2007, 12:17    Mesaj konusu: Alıntıyla Cevap Gönder
paylaşım için teşekkürler .
Kıdemli Üye
Kıdemli Üye
Üye No: 12
Kayıt: 14.10.2006
Puan: 10
Şehir: istanbul
MesajTarih: 20/11/2007, 12:47    Mesaj konusu: Alıntıyla Cevap Gönder
yerime eklediğin için sağolasın
Yeni mesaj yok Ansys Workbench Türkçe Eğitim Videoları burakoz1989 ANSYS 147 8/9/2018, 18:03 Son gönderilen mesajlar
pclokcer
Yeni mesaj yok SolidWorks Eğitim Videoları izleyin (... miramax Solidworks Görsel Derslerimiz 62 28/7/2017, 21:14 Son gönderilen mesajlar
fiducia
Yeni mesaj yok Önemli: PHP Programlama Eğitim CD eisentein PHP/ASP/HTML/CGI/JAVA/PYTHON 18 28/11/2009, 22:15 Son gönderilen mesajlar
theapow
Yeni mesaj yok Önemli: CNC Programlama aabanozcu Cnc-Torna ..vb tezgahlar(Talaşlı im.) 108 14/12/2016, 22:05 Son gönderilen mesajlar
aborijin
Yeni mesaj yok Önemli: Veritabanı Programlama aabanozcu VB/C,C++,/Fortran 20 20/12/2015, 21:14 Son gönderilen mesajlar
hazelnut
Yeni mesaj yok Önemli: cnc takım tezgahlarını tanıma ve prog... by_EpYn Endüstri Mühendisleri 36 12/9/2016, 15:53 Son gönderilen mesajlar
haydarcan
Bu başlık kilitlenmiştir; cevap yazamaz, mesajları değiştiremezsiniz Önemli: CNC tezgahlar ,simulasyon programlama... tes999 Cnc-Torna ..vb tezgahlar(Talaşlı im.) 30 27/12/2008, 09:27 Son gönderilen mesajlar
Diabolic
Bu başlık kilitlenmiştir; cevap yazamaz, mesajları değiştiremezsiniz Önemli: Visual Basic.Net Programlama Dili Eği... huso Asp.NET/C#/VB.NET 0 15/12/2007, 16:36 Son gönderilen mesajlar
Yeni mesaj yok Önemli: ASP Eğitim aabanozcu PHP/ASP/HTML/CGI/JAVA/PYTHON 62 4/8/2015, 06:27 Son gönderilen mesajlar
othello76
Yeni mesaj yok Önemli: C++ C# Eğitim Videoları huso VB/C,C++,/Fortran 134 16/5/2016, 02:54 Son gönderilen mesajlar
uklnc
Kod Çalışma Süresi = 0.0677 saniye, SQL Sorgu Adedi = 28, GZIP = Kapalı Hata denetimi = Kapalı,
140401 Saldırı girişimi engellendi
