Run Time: 0.001293
Run Time: 0.000731
Run Time: 0.000271
Run Time: 0.002447
Run Time: 0.000534
Params: 0, wo , wo , XF\Pub\Controller\Forum, List, valid, , 1714972960,
Run Time: 0.000150
Run Time: 0.000609
Params: 1714972060
Run Time: 0.000414
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 162 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1714972060)
Run Time: 0.000586
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 162 | Using where |
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1712380960)
Run Time: 0.001231
Run Time: 0.000898
Run Time: 0.000726
Run Time: 0.000208
Run Time: 0.000285
Run Time: 0.003141
Run Time: 0.001296
Run Time: 0.000242
Run Time: 0.001897
