Run Time: 0.001128
Run Time: 0.000727
Run Time: 0.000295
Run Time: 0.002567
Run Time: 0.000893
Params: 0, wvc, wvc, XF\Pub\Controller\Forum, List, valid, , 1714791583,
Run Time: 0.000666
Params: 1714790683
Run Time: 0.000659
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 145 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1714790683)
Run Time: 0.000594
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 145 | Using where |
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1712199583)
Run Time: 0.001472
Run Time: 0.001262
Run Time: 0.000875
Run Time: 0.000227
Run Time: 0.000157
Run Time: 0.000250
Run Time: 0.000284
Run Time: 0.001482
Run Time: 0.001992
