Run Time: 0.001154
Run Time: 0.000208
Run Time: 0.000725
Run Time: 0.000308
Run Time: 0.004532
Run Time: 0.001023
Params: 0, tn, tn, XF\Pub\Controller\Forum, List, valid, , 1714925435,
Run Time: 0.000155
Run Time: 0.000765
Params: 1714924535
Run Time: 0.000468
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 147 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1714924535)
Run Time: 0.000643
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 147 | Using where |
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1712333435)
Run Time: 0.001401
Run Time: 0.001203
Run Time: 0.000856
Run Time: 0.000254
Run Time: 0.000325
Run Time: 0.000340
Run Time: 0.002984
Run Time: 0.002133
bytes_received | 946575 |
bytes_received_change_user_packet | 719458 |
bytes_received_real_data_ps | 707285 |
