Run Time: 0.001101
Run Time: 0.000236
Run Time: 0.000240
Run Time: 0.000817
Run Time: 0.002608
Run Time: 0.000979
Params: 0, t3u, t3u, XF\Pub\Controller\Forum, List, valid, , 1714860748,
Run Time: 0.000149
Run Time: 0.000793
Params: 1714859848
Run Time: 0.000624
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 108 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1714859848)
Run Time: 0.000727
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 108 | Using where |
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1712268748)
Run Time: 0.001277
Run Time: 0.001250
Run Time: 0.000857
Run Time: 0.000247
Run Time: 0.000303
Run Time: 0.000441
Run Time: 0.002042
Run Time: 0.000352
Run Time: 0.000249
Run Time: 0.002117
