Run Time: 0.001292
Run Time: 0.000242
Run Time: 0.000211
Run Time: 0.000778
Run Time: 0.000286
Run Time: 0.002351
Run Time: 0.000600
Params: 0, t(5, t(5, XF\Pub\Controller\Forum, List, valid, , 1714799772,
Run Time: 0.000149
Run Time: 0.000765
Params: 1714798872
Run Time: 0.000540
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 147 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1714798872)
Run Time: 0.000619
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 147 | Using where |
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1712207772)
Run Time: 0.001398
Run Time: 0.001178
Run Time: 0.000926
Run Time: 0.000279
Run Time: 0.000204
Run Time: 0.000288
Run Time: 0.000355
Run Time: 0.001543
Run Time: 0.000204
Run Time: 0.002139
