Run Time: 0.001154
Run Time: 0.000208
Run Time: 0.000682
Run Time: 0.000292
Run Time: 0.002302
Run Time: 0.000495
Params: 0, ߠ=, ߠ=, XF\Pub\Controller\Forum, List, valid, , 1714740918,
Run Time: 0.000138
Run Time: 0.000748
Params: 1714740018
Run Time: 0.000383
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 103 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1714740018)
Run Time: 0.000512
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 103 | Using where |
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1712148918)
Run Time: 0.001351
Run Time: 0.001076
Run Time: 0.001124
Run Time: 0.000249
Run Time: 0.000691
Run Time: 0.000254
Run Time: 0.000451
Run Time: 0.001385
Run Time: 0.000189
Run Time: 0.001962
bytes_received | 941867 |
bytes_received_change_user_packet | 714750 |
proto_binary_fetched_bit | 2910 |
bytes_received_real_data_ps | 702723 |
