Run Time: 0.000838
Run Time: 0.000189
Run Time: 0.000682
Run Time: 0.002495
Run Time: 0.000618
Params: 0, v , v , XF\Pub\Controller\Forum, List, valid, , 1714220407,
Run Time: 0.000890
Params: 1714219507
Run Time: 0.000404
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 64 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1714219507)
Run Time: 0.000726
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 64 | Using where |
Run Time: 0.000291
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1711628407)
Run Time: 0.001214
Run Time: 0.001634
Run Time: 0.000941
Run Time: 0.000229
Run Time: 0.000381
Run Time: 0.001562
Run Time: 0.000253
Run Time: 0.002083
bytes_received | 941850 |
bytes_received_change_user_packet | 714733 |
proto_binary_fetched_bit | 2910 |
bytes_received_real_data_ps | 702684 |
