Run Time: 0.001218
Run Time: 0.000285
Run Time: 0.000728
Run Time: 0.000315
Run Time: 0.002433
Run Time: 0.000549
Params: 0, K, K, XF\Pub\Controller\Forum, List, valid, , 1715112094,
Run Time: 0.000134
Run Time: 0.000594
Params: 1715111194
Run Time: 0.000409
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 167 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1715111194)
Run Time: 0.000572
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 167 | Using where |
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1712520094)
Run Time: 0.001412
Run Time: 0.001245
Run Time: 0.000959
Run Time: 0.000285
Run Time: 0.000310
Run Time: 0.001749
Run Time: 0.001781
