Run Time: 0.001461
Run Time: 0.000246
Run Time: 0.000268
Run Time: 0.000797
Run Time: 0.000304
Run Time: 0.002648
Run Time: 0.000595
Params: 0, ݁, ݁, XF\Pub\Controller\Forum, List, valid, , 1714854535,
Run Time: 0.000141
Run Time: 0.000804
Params: 1714853635
Run Time: 0.000542
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 134 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1714853635)
Run Time: 0.000607
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 134 | Using where |
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1712262535)
Run Time: 0.001726
Run Time: 0.001124
Run Time: 0.000858
Run Time: 0.000259
Run Time: 0.000342
Run Time: 0.000256
Run Time: 0.000313
Run Time: 0.000359
Run Time: 0.001989
Run Time: 0.000211
Run Time: 0.002234
bytes_received | 941619 |
bytes_received_change_user_packet | 714502 |
proto_binary_fetched_bit | 2921 |
bytes_received_real_data_ps | 702499 |
