Run Time: 0.000976
Run Time: 0.000806
Run Time: 0.000356
Run Time: 0.002642
Run Time: 0.000575
Params: 0, 4~J, 4~J, XF\Pub\Controller\Forum, List, valid, , 1714705828,
Run Time: 0.000725
Params: 1714704928
Run Time: 0.000482
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 72 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1714704928)
Run Time: 0.000696
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 72 | Using where |
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1712113828)
Run Time: 0.002091
Run Time: 0.001040
Run Time: 0.001103
Run Time: 0.000270
Run Time: 0.000312
Run Time: 0.000299
Run Time: 0.000376
Run Time: 0.001876
Run Time: 0.002055
bytes_received | 942112 |
bytes_received_change_user_packet | 714995 |
proto_binary_fetched_bit | 2920 |
bytes_received_real_data_ps | 702956 |
