Run Time: 0.001550
Run Time: 0.000784
Run Time: 0.002488
Run Time: 0.000643
Params: 0, Q^, Q^, XF\Pub\Controller\Forum, List, valid, , 1715079254,
Run Time: 0.000742
Params: 1715078354
Run Time: 0.000578
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 105 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1715078354)
Run Time: 0.000733
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 105 | Using where |
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1712487254)
Run Time: 0.001560
Run Time: 0.001300
Run Time: 0.000988
Run Time: 0.000209
Run Time: 0.000222
Run Time: 0.000236
Run Time: 0.000308
Run Time: 0.000386
Run Time: 0.001599
Run Time: 0.000204
Run Time: 0.002660
