Run Time: 0.001284
Run Time: 0.000263
Run Time: 0.000824
Run Time: 0.000329
Run Time: 0.002954
Run Time: 0.000649
Params: 0, M, M, XF\Pub\Controller\Forum, List, valid, , 1714980974,
Run Time: 0.000513
Run Time: 0.000729
Params: 1714980074
Run Time: 0.000477
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 121 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1714980074)
Run Time: 0.000695
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 121 | Using where |
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1712388974)
Run Time: 0.001455
Run Time: 0.001887
Run Time: 0.000942
Run Time: 0.000274
Run Time: 0.000257
Run Time: 0.000260
Run Time: 0.000282
Run Time: 0.000378
Run Time: 0.001535
Run Time: 0.003939
