Run Time: 0.001214
Run Time: 0.000724
Run Time: 0.000634
Run Time: 0.002857
Run Time: 0.000556
Params: 0, ܚ), ܚ), XF\Pub\Controller\Forum, List, valid, , 1714217782,
Run Time: 0.000151
Run Time: 0.000786
Params: 1714216882
Run Time: 0.000399
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 76 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1714216882)
Run Time: 0.000587
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 76 | Using where |
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1711625782)
Run Time: 0.001563
Run Time: 0.001089
Run Time: 0.000956
Run Time: 0.000284
Run Time: 0.000210
Run Time: 0.000263
Run Time: 0.000252
Run Time: 0.000291
Run Time: 0.001317
Run Time: 0.001948
bytes_received | 941620 |
bytes_received_change_user_packet | 714503 |
proto_binary_fetched_bit | 2900 |
bytes_received_real_data_ps | 702466 |
