Run Time: 0.001264
Run Time: 0.000222
Run Time: 0.000752
Run Time: 0.000311
Run Time: 0.002762
Run Time: 0.000649
Params: 0, w{O, w{O, XF\Pub\Controller\Forum, List, valid, , 1714770322,
Run Time: 0.000950
Params: 1714769422
Run Time: 0.000535
SIMPLE | xf_session_activity | range | view_date | view_date | 4 | | 129 | Using where |
WHERE (`xf_session_activity`.`user_id` > 0) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND ((`xf_session_activity`.`user_id` = 0) OR (`xf_user_User_1`.`visible` = 1 AND `xf_user_User_1`.`user_state` = 'valid')) AND (`xf_session_activity`.`view_date` >= 1714769422)
Run Time: 0.000631
SIMPLE | xf_session_activity | range | PRIMARY,view_date | view_date | 4 | | 129 | Using where |
WHERE (`xf_forum_Forum_1`.`find_new` = 1) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`last_post_date` > 1712178322)
Run Time: 0.001553
Run Time: 0.001041
Run Time: 0.001012
Run Time: 0.000282
Run Time: 0.000222
Run Time: 0.000248
Run Time: 0.000316
Run Time: 0.000274
Run Time: 0.000311
Run Time: 0.001445
Run Time: 0.002059
